Drives: 2017 Toyota 86 (Raven)
PLS HELP!?! Rear left brake locking up after wheel stud replacement.
Had a stripped wheel stud and followed youtube videos on how to fix it. Remove wheels, remove caliper and place carefully and securely on cv axle, remove brake rotor etc; but after putting everything back together and taking it for a test drive i noticed a burning brake smell almost like the burning clutch smell and when i stepped out that same wheel area is lightly smoking. Went back home and didn’t go too far maybe 2 miles in total. The emergency brake doesn’t feel as tight as well but i heard that can be fixed reversing and over time. But is it too late to fix it myself or would i have to take it to a shop? I haven’t replaced the brake pads, rotors, etc since i’ve got the car but after seeing yesterday they all seem to be in well condition. There’s no brake fluid leaking so i don’t know what went wrong.
Wheels for Brains
Did you properly set the parking brake adjustment screw?
If it's set too tight on either wheel, the parking drum brake will be constantly applied and drag |
recently jus got it fixed by a referred mechanic, i think what he was trying to explain is what ur telling me now. If i had a visual i’d better understand but should i be worried about premature wear on that screw even with the little travel i did when too tight
#4 | |
Wheels for Brains
If the brake is dragging enough to be smoking, it will generate a lot of heat which can warp components and wear down the parking brake pad. Adjust the parking brake and spin the wheel by hand. It should move easily with little resistance. If the adjustment lever is set properly, your emergency brake lever should feel properly tight as well |
#5 | |
No you do not need to worry about anything. That short a trip would do little if any damage. The mechanic would have inspected it and told you if there were any issues.
#6 | |
but you live and u learn. will keep this in mind when i’m replacing the rest of the studs on the car
#8 | |
Wheels for Brains
Yes to clarify, if you drove the car with a smoking brake for an extended amount of time (hours, days), it will be bad. A short trip around the block you should be fine. |
| Wheel stud replacement | Dave-ROR | DIY (Do-It-Yourself) Guides | 267 | 01-21-2022 08:20 PM |
| Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style | Dake | DIY (Do-It-Yourself) Guides | 24 | 10-07-2020 11:56 AM |
| Just another wheel stud replacement video. | mhightower | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 04-26-2017 03:01 PM |
| South Bay Wheel Stud Replacement? | HachiRo | Northern California | 4 | 02-04-2016 04:56 PM |
| Replacement Lug Stud/Wheel Hub | swift996 | Issues | Warranty | Recalls / TSB | 3 | 08-30-2013 01:58 PM |
