Old 12-05-2022, 02:56 PM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Is my 86 healthy??
I looked at my diagnostics with the OFT v2 tablet and wanted to know if everything’s running fine. I had it parked and idling while I ran the diagnosis. But as far as under the hood goes I’ve only added JDL UEL headers, a GrimmSpeed CAI and the Remark x FT Speed Quad Catback exhaust. I’ve had the tune on for some time. And I do my regular oil changes every 3-5k miles.
blakkoutdarko is offline   Reply With Quote
Old 12-05-2022, 03:03 PM   #2
Teseo
Drives: frs
Better do a Compression Test and Blackstone Lab oil analysis.
Teseo is online now   Reply With Quote
The Following 4 Users Say Thank You to Teseo For This Useful Post:
humfrz (12-05-2022), Spuds (12-05-2022), Ultramaroon (12-05-2022), x808drifter (12-06-2022)
Old 12-05-2022, 03:24 PM   #3
humfrz
What do you see that leads you to make that recommendation?
Old 12-05-2022, 03:27 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
You don't see it? I see it.
alphasaur (12-05-2022), humfrz (12-05-2022), x808drifter (12-06-2022)
Old 12-05-2022, 03:28 PM   #5
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
From what I can see, none of those things on the OFT indicate there's a problem.
I think the better question, is why are you asking if it's healthy? Is it characteristically doing something wrong? CEL? Running rough? Weird sounds?
If not, a compression test and oil analysis will tell you more.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 12-05-2022, 03:31 PM   #6
Ultramaroon
not playing cards
OP, Teseo's just yanking your chain.
While driving, glance at your long-term fuel trim and knock correction for the most important indicators. LTFT should be within +/- 5% -ish. Shouldn't have any knock correction.
Looks golden at idle.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
blakkoutdarko (12-08-2022), humfrz (12-05-2022), Spuds (12-05-2022), Teseo (12-05-2022), x808drifter (12-06-2022)
Old 12-05-2022, 03:33 PM   #7
humfrz
OK, soooooooo, ya wanna share what you "see"?
Old 12-05-2022, 03:45 PM   #8
Ultramaroon
not playing cards
I see a smoothly idling engine.
blakkoutdarko (12-05-2022), humfrz (12-05-2022)
Old 12-05-2022, 04:35 PM   #9
Sasquachulator
Pavement Grey
Numbers on a screen! duh!!
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post:
Old 12-05-2022, 06:18 PM   #10
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Uhh... Advance multiplier is 0. That seems bad. You normally want that at 1. (Edit, unless the tune has IAM set to 0, but that seems odd for an OFT tune)
OP, take a log and post it to datazap or something. Screenshots don't actually tell anyone much of anything.
Also an oil analysis will tell you how the hardware inside the engine is doing.
Edit:. Wow, how'd you screenshot stft at 0? That's normally all over the place.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
blakkoutdarko (12-08-2022), Ultramaroon (12-05-2022)
Old 12-05-2022, 07:59 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Depending on injection mode it could go to 0 on stft I believe. That's why you usually log injection mode too.
IAM at 0 is weird. I almost think there is an issue with the OFT reading correctly. Possibly need to unplug and reconnect the OFT and the cable into the OBD2 and check again. If it was actually at 0 on IAM it would feel really really sluggish.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
blakkoutdarko (12-08-2022), Spuds (12-05-2022), Ultramaroon (12-06-2022)
Old 12-07-2022, 09:21 AM   #12
Spuds
The Dictater
Spuds's Avatar
Hey, you're right!
https://www.ft86club.com/forums/showthread.php?t=126500
I even knew about that at one point...
The Following User Says Thank You to Spuds For This Useful Post:
NoHaveMSG (12-07-2022)
Old 12-07-2022, 11:52 AM   #13
Ultramaroon
not playing cards
Hey, you're right!
I see that now! Thanks for linking threads.
Old 12-07-2022, 01:20 PM   #14
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
"Now cough ...
Again ... "
soundman98 (12-07-2022)
Is this a healthy log? D00C cookiesowns Software Tuning 3 08-26-2014 04:39 AM
Is she healthy, log. OFT v86 Software Tuning 7 08-18-2014 08:29 PM
◙◙◙ The "Keep Your Car Running Healthy" Thread | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 36 06-07-2013 02:26 PM
