Old 07-12-2022, 01:08 PM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
How to install OEM steering rack?
Is the install hard? I ordered (part number SU003-00841) from toyotapartsdeal.com and it comes with tie rods, I recently replaced the right side passenger LCA and went OEM and it was a perfect fit. Not sure if I should replace the left LCA as well, anyways putting the car on a lift I seen a crack in the steering rack, surprisingly the car drove fine besides needing an alignment. Long story short what tools are needed and what should I keep note of if I’m doing this install myself? Can it be done in a few hours if I did this solo?
blakkoutdarko is offline   Reply With Quote
Old 07-12-2022, 08:33 PM   #2
https://gt86stuff.onrender.com/t3Portal/
Courtesy of Ultramaroon
blakkoutdarko (07-12-2022)
Old 07-12-2022, 09:47 PM   #3
blakkoutdarko
You stay coming through Tcoat, I’m trying to find out how to find the instructions for the steering rack but Thanks!
Old 07-13-2022, 06:44 AM   #4
The full instructions for the rack will be in the service manual.
blakkoutdarko (07-13-2022)
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
FS: Perrin Steering Rack Lockdown Kit and STI Steering Rack Long Bolts Kit neilvosko Brakes, Suspension, Chassis 3 04-10-2018 05:48 PM
FS: OEM Steering Rack MicheleAbbate Brakes, Suspension, Chassis 0 04-18-2016 02:51 PM
Perrin Steering Rack Lockdown Install and Review Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-13-2015 11:58 PM
