follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Go to Page...
Sign Up
Showing results 1 to 17 of 17
Search took
0.00
seconds.
Search:
Posts Made By:
Illuminaughty
Forum:
Software Tuning
12-01-2015, 09:48 PM
7
Introduce yourself!
1,633
Posted By
Illuminaughty
Name: Nick Location: Boynton Beach, FL ...
Garage: '13 BRZ 1993 Sierra 1500
Interests: Tuning, Karting, Boarding (All kinds), Counter-Strike, and cars of course!
Previous: '01 Jetta '97 F150
Forum:
Forced Induction
09-29-2015, 09:24 AM
2,361
NEW for 2021: SBD G500X Ball-Bearing Turbo Kit: $2999
621,981
Posted By
Illuminaughty
Just peeking my head in here because it's been a...
Just peeking my head in here because it's been a while. I've been running this kit for around 9 months and 15k miles. I daily drive around 70 miles a day round trip to work. So far this kit has given...
Forum:
Software Tuning
06-04-2015, 02:36 PM
11
detecting knock on stock ecu
5,896
Posted By
Illuminaughty
Welcome bud. If you're already editing ROM-files...
Welcome bud. If you're already editing ROM-files and pulling logs, this should help immensely.
http://www.romraider.com/forum/topic1840.html
Edit: Keep in mind this is older and we're on a...
Forum:
Forced Induction
05-29-2015, 03:15 PM
38
Nate's SBD/ZAGE Turbo Kit (DYNO Tune) by Bill@Delicious Tuning
19,900
Posted By
Illuminaughty
The first night we did a few pulls with me at...
The first night we did a few pulls with me at 7PSI and with a passenger (extra 110lbs or ~50kg) and he'd consistently pull me by a car or so. At 10PSI with no passenger it was a much different story...
Forum:
Forced Induction
05-29-2015, 01:24 PM
38
19,900
Posted By
Illuminaughty
SBD Kit checking in, I'm currently running 7PSI...
SBD Kit checking in, I'm currently running 7PSI on E85 on a tune I made myself (using Shiv's 93 OFT SBD tune as a base). I've yet to hop on a dyno but I'm running some really conservative timing so...
Forum:
Forced Induction
05-29-2015, 09:49 AM
21
Negative Short term fuel trims at idle w/ no obvi leak
10,604
Posted By
Illuminaughty
I know this was like ten days ago but I noticed...
I know this was like ten days ago but I noticed nobody's answered. If you scaled your MAP sensor in the tune using your bad sensor then yes you'd need to rescale with the good sensor then reflash. If...
Forum:
Forced Induction
05-28-2015, 02:46 PM
8
Deliciou Tuning Speed Density Tunes - Important Notes and Closed Loop Fuel Correction
4,455
Posted By
Illuminaughty
Ah okay perfect, I've seen a lot of the work you...
Ah okay perfect, I've seen a lot of the work you guys do so your words hold a lot of weight for me personally. I appreciate the response :)
Forum:
Software Tuning
04-04-2015, 11:10 AM
29
Advice on creating an E85 FI Tune with Openflash
10,920
Posted By
Illuminaughty
I'd be more than happy to collaborate on...
I'd be more than happy to collaborate on something. What kind of program do you think would be useful? Most of the work I do is analyzing or trending parameters to determine performance...
Forum:
Software Tuning
04-03-2015, 08:42 AM
29
10,920
Posted By
Illuminaughty
Hello friends,
Ive been running the SBD Turbo for a little over a month now using Shivs OTS tune for it on 93 pump gas. I'm currently running only 7psi, since I've been trying to learn as much as...
Forum:
Forced Induction
03-16-2015, 10:22 PM
27
Poll:
Poll: FI with/without an oil cooler
7,269
Posted By
Illuminaughty
Ask away I love people that go out of their way...
Ask away I love people that go out of their way to do research. ~500 miles on the turbo, currently running 5W-20 Penzoil Platinum Pure Plus. Not my endgame choice of oil but I figured I'll change it...
Forum:
Forced Induction
03-15-2015, 11:27 PM
27
Poll:
7,269
Posted By
Illuminaughty
I have a 40 minute commute every day to work and...
I have a 40 minute commute every day to work and back. Max temps I've seen on this drive were 226F. Granted it was a pretty relaxed drive, that seems pretty safe for now. No oil cooler and running...
Forum:
Forced Induction
03-12-2015, 10:00 AM
2,361
621,981
Posted By
Illuminaughty
The wastegate is what allows air to bypass the...
The wastegate is what allows air to bypass the turbine (hot side) of the turbo past a certain boost threshold so that you can limit the amount of pressure the turbo produces. It has a line that...
Forum:
Forced Induction
03-11-2015, 11:08 AM
2,361
621,981
Posted By
Illuminaughty
From what I've gathered, the stock fuel system...
From what I've gathered, the stock fuel system (injectors and fuel pump) can handle up to somewhere around ~300whp. I'd personally try to not go too near that mark, as I like to err on the side of...
Forum:
Forced Induction
03-11-2015, 12:41 AM
2,361
621,981
Posted By
Illuminaughty
That's the BOV you guys got. The springs are...
That's the BOV you guys got. The springs are rated for different pressures I'd assume. Also my earlier post about the vacuum line being 1/2" and not 3/8" was incorrect. Chris was absolutely right the...
Forum:
Forced Induction
03-10-2015, 03:14 PM
2,361
621,981
Posted By
Illuminaughty
Tried to give it a go without them then ended up...
Tried to give it a go without them then ended up using the Greddy instructions as a general guide. It would have been possible to do with no instructions at all, just would've taken a bit more time....
Forum:
Forced Induction
03-10-2015, 01:52 PM
2,361
621,981
Posted By
Illuminaughty
First off, I got this kit installed over the...
First off, I got this kit installed over the weekend and have to say it is working extremely well. Installation was not bad by any means, but definitely ask for the instructions beforehand as they'll...
Forum:
Forced Induction
02-19-2015, 03:51 PM
2,361
621,981
Posted By
Illuminaughty
Just got my kit ordered thanks to Chris...
Just got my kit ordered thanks to Chris spdbydesign! Incredibly good customer service, couldn't have been happier with the help received. Now I just wait for all the goodies to come in and off to the...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) — General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) — General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Transmission and Driveline
Wheels and Tires
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Coating and Customization Services
Exterior Parts - Lighting
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
09:10 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2026 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
