Old 03-23-2015, 10:10 AM   #1
2013GTRNate
2013GTRNate's Avatar
Nate's SBD/ZAGE Turbo Kit (DYNO Tune) by Bill@Delicious Tuning
I am looking forward to seeing what the final #s will be. I am guessing on the Infamous MUSTANG Dyno they should be near 400HP and 350TQ. My appointment is for the 25th of March so just a couple days away.
The BRZ has:
SBD Turbo Kit - Heat wrapped with PTP Turbo Blanket and wrap materials
550cc Side Port Injectors
Denso 265lph
Flex Fuel (E85)
Delicious Tuning MAP sensor and Boost Controller
EcuTek (Bill@Delicious)
Kite Oil Cooler (OEM Oil)
MOTIV - Over Pipe and Test Pipe
Greddy EVOlution GT Exhaust (Not in yet)
STAGE 3 South Bend Clutch
For now I still have the OEM wheels and tires.
-Nate
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
The Following User Says Thank You to 2013GTRNate For This Useful Post:
raven1231 (03-23-2015)
Old 03-23-2015, 10:50 AM   #2
raven1231
looking forward to this as well!
2013GTRNate (03-23-2015)
Old 03-23-2015, 12:00 PM   #3
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Shiv is working on a higher outout version of this kit designed to handle 10 to 11 psi. Will have different spring in wastegate. Different plumbing including air intake run out to front of grill to capture colder air. Should help you
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following 2 Users Say Thank You to Boofneenee For This Useful Post:
2013GTRNate (03-23-2015), el-92 (03-23-2015)
Old 03-23-2015, 06:13 PM   #4
wooly35
Drives: 2014 Scion FR-S LS3
Man, I cant wait for this upgrade. Im ready to get back to running e85.
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Old 03-23-2015, 07:05 PM   #5
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Just switched back to E85 2 wks ago. so muc more fun that 93. ttq dip gone for NA appllication. .E85 does not like cold weather
FRS
2013GTRNate (03-23-2015), raven1231 (03-23-2015)
Old 03-23-2015, 09:24 PM   #6
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
The BRZ has:
Denso 265lph
Flex Fuel (E85)
-Nate
Did your turbo blanket rub up against the Turbo's actuator rod? I tried to put a turbo blanket on my SBD turbo but part of it would always rub up against the actuator rod. I was afraid this would interfere with the wastegate opening and closing so I decided not to put the turbo blanket on.
xuimod is offline   Reply With Quote
The Following User Says Thank You to xuimod For This Useful Post:
Old 03-23-2015, 10:24 PM   #7
2013GTRNate
I haven't noticed it at this time. I went with the blanket recommended by PTP for that reason.
Old 03-24-2015, 06:48 AM   #8
erbaker67
erbaker67's Avatar
Drives: 2015 FRS RS1, 93 Supra
Looking forward to seeing everything. Looks great!
erbaker67 is offline   Reply With Quote
The Following User Says Thank You to erbaker67 For This Useful Post:
2013GTRNate (03-25-2015)
Old 03-26-2015, 11:40 AM   #9
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Any news?
RD1428 is offline   Reply With Quote
Old 03-26-2015, 04:15 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
x2!
Old 03-30-2015, 06:55 AM   #11
extreme-86
Drives: 86, Nissan 200SX, Honda Civic
Any updates ? Keen to see what numbers Delicious tuning's wizardry + FlexFuel pulls out of the SBD turbo kit.
extreme-86 is offline   Reply With Quote
Old 03-30-2015, 10:13 PM   #12
Nissota
Nissota's Avatar
Drives: Subaru BRZ, Nissan 240sx
Awaiting anxiously.....
Nissota
2013 Subaru BRZ DD
1997 Toyota Supra MKIV
1990 Nissan 240sx
www.revvolution.com
Nissota is offline   Reply With Quote
Old 03-31-2015, 06:03 PM   #13
RD1428
RD1428's Avatar
Old 04-01-2015, 09:34 AM   #14
Gavmen
Drives: dmg brz 2012
Hi all, thought I would chime in here WRT the SBD/Zage kit with the Delicious Tune and the wonderful tune they've done for my car.
Heres the dyno (numbers are RWKW)
This is on E85, the dyno shows 100RWKW at stock.
950cc Bosch injectors
265l DW Pump
Not aiming for higher numbers for now, since I'm on stock tyres.
Thanks Bill and Zach at Delicious Tuning.
Cheers
Gavin
Gavmen is offline   Reply With Quote
Delicious Tuning is the way to go for a custom tune. Canivideo User/Vendor/Sponsor Reviews, Feedback, Comments 5 01-13-2015 03:47 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
