Old 01-12-2016, 02:58 PM   #1
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Wilwood FNSL6R???
Can anybody give me some insight on the Wilwood 6 piston calipers? I plan on buying only the fronts to use for the track/autox as well as bling. The reason I'm leaning toward the wilwoods is because it can fit stock wheels ( i use the stocks as a spare). What pads are u using to maintain proper brake bias? For example what pads would work good for the wilwoods if I had PMU Club racers in the rear. I would keep upgrading the oem brakes but it seems that upgrading to a BBK is more cost effective.
Devil 86 is offline   Reply With Quote
Old 01-12-2016, 04:01 PM   #2
wparsons
wparsons's Avatar
If the brake kit itself doesn't change the bias, then just use the same pads front and rear. I'm not sure if those calipers change bias though.
flickr
Old 01-12-2016, 09:02 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Use this calculator to figure it out. You just need to input the correct front caliper specs and then mess around with brake pad cf to figure out what you need and then find a pad with that cf.
http://www.tceperformanceproducts.com/bias-calculator/
Ill save you a little time and tell you stock front bias is 69.7% (.697 on the calculator)
Old 01-12-2016, 09:56 PM   #4
Devil 86
Devil 86's Avatar
The calipers itself don't change bias much but running different front and rear pads do, which is what I'm worried about since the wilwood caliper doesn't seem to utilize the same brake pad options that the oem calipers have.
Old 01-12-2016, 10:18 PM   #5
acro
Drives: GT-86
Go Carbotech then, they have options to fit the willwood caliper up front and the OEM rear
acro is offline   Reply With Quote
Old 01-12-2016, 11:13 PM   #6
finch1750
finch1750's Avatar
Project Mu has a size for Wilwood according to their site it seems but doesn't break down compounds (http://www.project-mu.co.jp/usa/prod...ad_import.html). Maybe contact them or one of their dealers like CSG or Evasive
Old 01-12-2016, 11:45 PM   #7
Panman
Panman's Avatar
Drives: 86 GTS
Talk to @RR_Racing
Panman is offline   Reply With Quote
Old 01-13-2016, 03:44 PM   #8
acro
Drives: GT-86
Should tell u to talk to CSG Mike that's where I got mine from. Matching front and rear
@CSG Mike
Old 01-13-2016, 07:23 PM   #9
CSG has plenty of pad options that will fit the Wilwod SL6R.
Old 01-14-2016, 11:27 AM   #10
bhmax
Drives: 13 BRZ, 17 Focus RS
I might not have used the correct numbers, but came up with about 65%. Sounds like the RR Racing thread has shown shifting it towards the rear is working out well on their kits that do that. Looks like a pad with about .1mu higher in rear should shift bias about 5% on stock calipers. I'm looking at different Raybestos compounds to do that.
bhmax is offline   Reply With Quote
Old 01-22-2018, 07:41 PM   #11
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Bumping this thread because of the good title.
I am planning on running the PolyMatrix B pads in my 86 club racer, it has 500HP and the wilwood 6 piston front and 4 piston rear kit.
I have been running the BP20 pads but i want more endurance. Will i be able to get enough heat into the rear pads to get the polymatrix B pads into their efficient range? (in a 20Minute sprint)?
any help or insight appreciated
Surok is offline   Reply With Quote
Wilwood BBK for WRX - Fit to BRZ swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 05-03-2019 06:41 PM
Anyone else running Wilwood? hamlet Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-05-2013 08:20 PM
WRX rear wilwood would it fit? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-22-2013 09:26 AM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
