Old 01-12-2016, 12:41 AM   #1
Sherb
Drives: Brz
Question about OFT
So I was reading up on OFT and have a couple questions.
1. Does OFT allow tuners to dyno tune like how ECUtek does?
2. If I buy bolt one will the base stage one and two times recognize the change in MAF?
Sorry if they got answered in a thread but I did a search and couldn't really find it
Sherb is offline   Reply With Quote
Old 01-12-2016, 12:55 AM   #2
swarb
1. yes and no. The tablet itself does not do any adjustments, it just allows you to flash tunes used by rom raider. And pretty much no one tunes on oft because you can't lock the work like on ecutek. It allows the tuner to protect their work, and stops people from sharing the tune to everyone in the world.
2. Change in maf you have to calibrate yourself. There is a tutorial somewhere.
Old 01-12-2016, 04:31 AM   #3
Sherb
Drives: Brz
Question about OFT
Would oft display the current MAF with new parts on?
Old 01-12-2016, 05:41 AM   #4
swarb
Please direct your general oft question here Open Flash Tablet - OFT TIPS Trick’s & FAQ
Old 01-12-2016, 05:58 AM   #5
steve99
MAF is mass air flow sensor, unless you have changed your complete intake you dont usually need to rescale maf sensor . Drop in filters and silicone intake tubes are fine.
OFT will log and display many ECU parameters including those need to rescale maf sensor
Old 01-12-2016, 07:29 AM   #6
Sherb
Drives: Brz
I'm talking about for headers and when you start taking cats out and adding o2 sensor bungs in place
Old 01-12-2016, 08:01 AM   #7
steve99
r
The tunes that come with oft are for either stock car , car with catless el and uel header and for petrol or e85.
They are designed for stock intake.
Changing headers and removing cats does not require maf sensor rescaling .
It does require fuel table and intake exhaust cam table changes among other things.
The tunes for catless headers also disable P0420 cat efficiency cel code so no o2 spacer is needed.
unless you change intake to an aftermarket intake you dont need to change maf scaling.
it all done for you by tuner.
If you keep stock intake no maf scaling or other changes required just run the tune suppled that suits your header type and fuel ie 91\93\e85
The Following 3 Users Say Thank You to steve99 For This Useful Post:
FRSBRZGT86FAN (01-12-2016), Mr.Impreza (01-12-2016)
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
Serious question KslayFRZ Off-Topic Lounge [WARNING: NO POLITICS] 49 07-11-2013 04:46 AM
e85 question. feldy Engine, Exhaust, Transmission 24 04-03-2013 12:41 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
HID question mrlewistan Cosmetic Modification (Interior/Exterior/Lighting) 8 12-31-2012 08:49 AM
