Old 12-31-2012, 02:03 AM   #1
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
HID question
do i need two seperate ballast systems (4 total boxes?) if i want HID h11s and 9005s? Im pretty new to car mods so if this seems silly im sorry
mrlewistan is offline   Reply With Quote
Old 12-31-2012, 02:13 AM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Yup.. A ballast for each light
Gixxersixxerman is offline   Reply With Quote
Old 12-31-2012, 02:57 AM   #3
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
that seems like a crazy ton of clutter. i wonder if there are any like double ballast options out there
Old 12-31-2012, 03:02 AM   #4
Gixxersixxerman
They are pretty small.. They hide pretty easy
Old 12-31-2012, 03:10 AM   #5
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
thanks for your input gixxer
Old 12-31-2012, 03:37 AM   #6
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
i dont think u'll be needing the 9005 high beam on HIDs. with the H11 HIDs output would be enough. but its a personal preference tho.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 12-31-2012, 04:48 AM   #7
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
It's actually not too bad. Get the digital slim ballasts, plus the quality kits available from most of the vendors here have pretty long wiring. There's space on either side of the headlights, directly below each headlight housing area where you can throw two ballasts. The longer wires will let you mount your 3rd/4th ballasts farther back in the engine bay, possibly even as far back as the battery. I think that it may be possible to stick 4 ballasts in up in front as well, it'll just be a tight fit and you'll want to keep all the wires/cables well organized. If it really comes down to it, you can just remove the front bumper and you'll have tons of space to tuck a bunch of ballasts.
I personally have my low beam HID ballasts tied down/stuck down on the strut bars - pretty far back in the engine bay. I could fit another 2 ballasts down below right in front if needed.
All that said, +1 to what other guys have said about only need HID for low beams - the high beams don't really need to be HIDs. The aiming/beam pattern for high beams with a good pair of halogen bulbs is good enough visibility for me - they're usually only flicked on/off a few times or used for a short period of time anyway. Plus each time HID bulbs are turned on, it's ignited (a sharp voltage spike before it settles down to it's normal operating voltage). I've heard that repeated igniting is bad for the HIDs - something that would happen if you flick the high beams regularly (to signal to other drivers at night or something). I'd rather not have to replace the HID bulbs or ballasts if possible.
cdo221 is offline   Reply With Quote
Old 12-31-2012, 07:17 AM   #8
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
are there some good 9005 super brights you folks will recommend then instead of hid?
Old 12-31-2012, 07:49 AM   #9
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
If you can find HIRs that's what I would suggest.
I believe 9005 is 9011 in HIR. A Google search should help you out.
JWMotoring is offline   Reply With Quote
Almost there.....but question VENOM~ CANADA 25 08-22-2012 05:39 PM
Question? Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 7 07-28-2012 03:31 PM
mpg question jarviz Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 01:40 PM
Question for BRZ and GT-87 hps? west2k95 Scion FR-S / Toyota 86 GT86 General Forum 276 03-13-2012 10:45 PM
