Old 01-12-2016, 12:14 AM   #1
Thatguyjeremy
Drives: 13' Asphalt FRS
Noob question 18x9.5
Hello all,
I have a noob question.. I'm going to be ordering 18x9.5 wheels soon.. I don't quite know what I should get. +22 offset or +30.. Mind you the wheels are 5x114.3 and I'm going to be running an 11mm project kics adapter.. Please help a brethren out. Thanks
IG: __thatguyjeremy
Last edited by Thatguyjeremy; 01-12-2016 at 12:36 AM. Reason: Tiredness spell check
Thatguyjeremy is offline   Reply With Quote
Old 01-12-2016, 12:23 AM   #2
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
What you don't list that matters:
Tire size
Fender modifications
Suspension modifications
Given the missing info, there's no way to give you advice. That you didn't think to tell us means you're probably entirely stock, in which case neither of those offsets will come close to fitting. With an 11mm spacer, look for something near +50
sdemo is offline   Reply With Quote
Old 01-12-2016, 12:35 AM   #3
Thatguyjeremy
Tire size
You're right, missing a bit. Half asleep at work aha. Current set up is 17x9 +35 tires 235/45. With the 9.5 I was planning on running 245/35 or 40 tires to keep the same diameter ish. Tein basis coils with Beatrush pillow ball mounts and crash bolts. lowered 2" f/r and SPC RLca. Reason I ask is I don't see anywhere people running the 5x114 adapters with 9.5 wheels. And I'm not that intelligent when it comes to offset
IG: __thatguyjeremy
Old 01-12-2016, 12:42 AM   #4
sdemo
sdemo's Avatar
Check out willtheyfit.com to compare to your current setup. IMO, neither of those offsets will work with adapters without flares / major fender work or significant camber... but I don't know the limits of the SPC arms you have installed to know if you can make it work or not
Old 01-12-2016, 12:52 AM   #5
swarb
do some math.
17x9+35
vs 18x 9.5 +19 (+30-11spacer)
Increase 6.35mm ouside, and 6.35mm inside due to 12.7mm width added(.5inch)
35 offset -19 offset=16mm and 6.35 outside width added= 22.35mm
So you added around 7/8th's or 22.35mm in ouside width.
Go outside and see if you have room for that 22.35mm. You probably don't without 4-5++ degrees of camber.
The Following 2 Users Say Thank You to swarb For This Useful Post:
86kahl (01-12-2016), jawn (01-12-2016)
Old 01-12-2016, 12:52 AM   #6
whataboutbob
AutoX-10/10ths every run
http://www.ft86club.com/forums/showthread.php?t=7535
Build thread:Here
Noob question about OFT nyfries Software Tuning 4 12-09-2014 01:07 AM
noob question here about f.I.... zimzum Forced Induction 7 03-06-2014 05:24 AM
noob question ft86me Engine, Exhaust, Transmission 13 02-28-2013 05:53 AM
Noob Question.. wWaldo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-21-2013 09:04 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-03-2012 12:18 AM
