Old 01-09-2016, 11:01 AM   #1
Dembo
Drives: 2012 Grey GT86
Question Strut top nut help
I have KWv1s to install which reuse the OEM top mounts. Having got the front right strut out I found I couldn't budge the top nut at all. I was using a deep 17mm ring spanner about 9" long and an allen key with mole grips, and spring compressors to remove the load, but couldn't make it turn. I tried the other one that was still on the car, but that didn't want to move either.
Any tips? Is an impact driver the only way? Surely that risks damaging the shock.
The other option is that I get some mounts from somewhere and leave the old strut assembled, which at least make it easier to swap back if I ever want to. But it's not entirely clear from the instructions which bits I need.
Thanks for any advice.
Dembo is offline   Reply With Quote
Old 01-09-2016, 11:44 AM   #2
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I have used a electric impact and a vise grip to get mine apart a couple times now. Use the vise grip on the strut rod to make sure it doesn't spin and use the impact on the nut. I don't see the use of stock struts if your moving to KWv1's.
You can do it with a open socket and an allen key just takes more force from you to get it to loosen.
Shneegle is offline   Reply With Quote
Old 01-09-2016, 12:31 PM   #3
JSanders
FR-S Newb
JSanders's Avatar
If you go with the plier/vice grip idea (which does work) PLEASE put a rag on the strut before you grip it with the pliers. Reduces the rick of damage if it spins. When I disassemble strut assemblies at work, I compress the spring and can usually reach in and grasp the strut by hand enough to break the nut loose with an electric 3/8" impact. Best of luck!
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
JSanders is offline   Reply With Quote
Old 01-09-2016, 02:36 PM   #4
stevesnj
stevesnj's Avatar
I used a pipe wrench so I didn't have to buy the special tool
My 2016 Build thread
Old 01-09-2016, 02:42 PM   #5
Dembo
Yes that's what I need. I was trying to work out if I could grip a socket with something whilst sticking the allen key through the middle.
I'm amazed you can get a good enough grip on the shaft, but I'll give it a go.
Thanks for replies.
Old 01-09-2016, 02:51 PM   #6
cnk
Drives: '13 DGM BRZ Limited
Get some pass through sockets. Makes life much easier.
Sent from my SAMSUNG-SM-N910A using Tapatalk
cnk is offline   Reply With Quote
Old 01-09-2016, 03:59 PM   #7
ryoma
ryoma's Avatar
I used a pass through socket and an allen key tool with pliers grabbing the short end on the allen key. I did it with my car on the ground then jacked it up. I wasn't going to risk messing up my fingers with a spring compressor lol. though, I did have to use a cheater bar on my passenger side front nut. the driver side got loose easily.
I bought a set of pass through sockets from Harbor Freight for $20. they aren't that expensive
Old 01-10-2016, 10:26 PM   #8
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Lowers has a fantastic set from kobalt for just $19. I literally changed all four springs yesterday. Use an extension. We literally used the handles off of two floor jacks and slide the pass through into one and the long end of a 6mm Allen key in the other. Worked like a CHARM. We did use spring compressors though (full disclosure).
Keenercarguy is offline   Reply With Quote
Old 01-11-2016, 06:40 AM   #9
Dembo
Ta. I've ordered some pass through sockets so we'll see how that goes. Hopefully they'll turn up for the weekend.
Strut Bar Review: AEM Strut Bar Thoughts and Experiences wu_dot_com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-08-2019 04:33 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 10:31 PM
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 09:06 AM
WTB Cusco Carbon Fiber Front Strut Bar w/ MCB and Cusco Carbon Fiber Rear Strut Bar FR-S Matt Want-To-Buy Requests 0 12-04-2013 05:10 PM
