Old 01-05-2016, 12:23 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
headlight bulb
I am going to change my 2013 10-series HID headlight bulb.
Just want to make sure before I make a purchase, the headlight bulb is D4S?
For example, is this one going to work?
http://www.ebay.com/itm/2x-D4S-D4R-H...0aWypw&vxp=mtr
Thanks
FR-Sky is offline   Reply With Quote
Old 01-05-2016, 01:24 AM   #2
NahumCC
Drives: 2013 FR-S 10 Series
Yes, it is a D4S 35 watt HID bulb.
NahumCC is offline   Reply With Quote
Old 01-05-2016, 02:26 AM   #3
ryoma
ryoma's Avatar
be aware of buying cheap bulbs off of ebay. there's a higher chance that they are defective than a more reputable seller such as TRS or Diode Dynamics. definitely test your bulbs for a few days and see if they work properly because the last thing you want is one or both of them not working when you need them to.
Old 01-05-2016, 03:14 AM   #4
FR-Sky
FR-Sky's Avatar
Thank you both of you.
Headlight bulb replacement Alupinski Cosmetic Modification (Interior/Exterior/Lighting) 2 03-30-2015 04:02 PM
Headlight Bulb Install OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 3 07-23-2014 11:25 PM
Best bulb for reflector headlight? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 2 02-08-2014 09:33 AM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-28-2013 11:00 PM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 02:48 PM
