Old 07-23-2014, 06:56 PM   #1
OURO3OROS
Drives: 2013 Asphalt FR-S
Headlight Bulb Install
I have the Winjet headlight and a bulb died. I replaced it but the output was horrible. It turns out I hadn't installed it well. Before attaching the retaining cup, I can't get the bulb to stay, orb"lock," in place. What gives? Which direction should the nub on the H7 point?
OURO3OROS is offline   Reply With Quote
Old 07-23-2014, 07:36 PM   #2
illicitstylz
Drives: 2014 FRS - Whiteout - 6spd MT
if you can't figure out how to match 3 knobs from the base of the head light bulb to the 3 knobs to the headlight socket, you should just ask someone else to do it for you. srs
illicitstylz is offline   Reply With Quote
Old 07-23-2014, 10:06 PM   #3
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I believe your thinking on an h11 bulb. As for h7 It should only go one way. I don't have the winjets so I can't confirm
Chen is offline   Reply With Quote
Old 07-23-2014, 11:25 PM   #4
OURO3OROS
Issues resolved: the retainer around the bulb was bent so it wouldn't sit flush.
Best bulb for reflector headlight? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 2 02-08-2014 09:33 AM
BRZ and FR-S HID Headlight Bulb Upgrade | BRZ FR-S Video JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 9 02-08-2014 12:34 AM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-28-2013 11:00 PM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 02:48 PM
22w LED H11 Headlight Bulb (from AutomationLED) Review Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 10 04-02-2013 06:02 AM
