G20 Guru
Monogram Push Start Issue
Hi Everyone,
Not sure if any of the Monogram/ 10 Series/ Limited people are having this issue. Lately, I've come across while trying to start my car (AT), the car doesn't start. All the lights on the dash will light up, the radio works, the green light comes on that it recognizes the key, and the steering wheel isn't locked. I've also tried unplugging the battery to reset the car, still no luck. And I changed the batteries inside the key fobs. I also heard the cell phone can interfere, so I've also tried turning the phone off. Thing is, the immobilizer light will flash and the green key light is solid. It doesn't do it all the time, and usually if I wait around for about 30 minutes or so, the car will eventually start. Only thing I can think of is my battery could be dying. 2014 model with 60k miles. Any ideas?
Slowmatic Drfiterz, from P to D in a heartbeat. Last edited by Ak1m0to; 01-04-2016 at 01:02 PM. |
Not Bаnned Anymore
Drives: Heavily Modified FRS
My guess is battery
Yep, that would be my guess too.
I suggest you check the battery: http://www.aa1car.com/library/battery_runs_down.htm Or, take the car into a shop and have them do a "load test" on the battery. Life is too short to put up with a weak battery..... ![]() humfrz |
Drives: 2014 Monogram FRS Whiteout
Im jumping on the battery train as well. I thought someone had a similar issue and it was the battery or my mind could be making things up. Though battery would definitely be the first thing to check especially during this time of year and the changing temps.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl |
My usual response to these is unhook the battery and hook it back up to reset but since you have already done that I will hop on the battery train as well. A dying battery can do the weirdest stuff sometimes.
#6 | |
![]() humfrz |
Mentat
Drives: 2013 Scion FRS 6MT
Too bad you have an automatic. Otherwise you could push start it.
Drives: 2015 CWP BRZ Limited
Sounds like a dying battery to me.
#10 |
G20 Guru
Well, I changed the battery this past weekend and while leaving work yesterday, the car didn't want to start up again.
After trying different things like locking the car, going outside, wait for the factory alarm to set, unlock, get try to start, ect... The car finally started about 30 minutes later. Only thing I can really think of now is maybe bad ECU? I have enough juice on the battery and the alternator is reading just fine. Any other ideas?
Slowmatic Drfiterz, from P to D in a heartbeat. |
#11 | |
Are you sure the new battery had a full charge .. ?? (it wouldn't be the first one - weak off the shelf) Did you clean the inside of the battery cable clamps .. ?? When you say "it won't start" does it turn over and not fire ..... or nothing happens when you hit the start button .. ?? Does it go: click-click-click after you push the start button .. ?? (heck, I don't even know if they do that anymore ..... ).DANG electronics ....... ![]() Back in the day, I would suggest you check the cable connection on the starter. Then check the battery ground connection to the block/frame. However, you may have to take it into the dealer ...... ![]() humfrz |
#12 | |
#13 |
Drives: 2013 FR-S 10 Series
Two switches to check come to mind and I don't know if they have them for certain since I have a manual. Someone will correct me if I'm wrong.
There are generally two switches that can stop you from getting a push button car started. The first is a brake switch and the other is gear selector position sensor. The first switch's job is obvious. The other switch, sometimes referred to as a NSS (Neutral Safety Switch) is meant to prevent an automatic from being started in anything other than park or neutral. |
#14 | ||
G20 Guru
Clean all the terminals and applied a little dielectric grease to both terminals. Everything turns on, radio, lights, gauges, but the car doesn't turn over. It's as if I only hit the push button without pressing the brake or clutch pedal. Only thing I have plugged in is my radar, and phone charger. Recently, I've been unplugging those items when I shut the car off to make sure nothing is draining the battery. I've made a habit to shut the radio off, turn off the A/C, unplug the radar and charger before I turn the car off. No OFT, car is tuned via ECUTEK by Motoeast. Quote:
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| STI Push Start | Inextirpable | CANADA | 1 | 03-15-2013 02:52 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
| GTS come with push start? | adam | AUSTRALIA | 13 | 06-04-2012 03:28 AM |
