Old 01-04-2016, 09:40 AM   #1
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Trailing Arm Bushing Question?
I recently picked up most of the Whiteline bushings available for the FRS. I didn't seem to find one for the rear trailing arm bushing on the spindle/knuckle side of the arm. They do have a bushing for the lower arm on the spindle/knuckle side. Is it the same bushing and I need another set? They seam to have all of the other bushings or am I just not reading the product list properly?
TRAKRAVN is offline   Reply With Quote
Old 01-04-2016, 11:41 AM   #2
TRAKRAVN
I was able to find this today.
http://www.ebay.com.au/itm/Hardrace-...QAAOSwzrxUt1AA
Does anyone have any experience with these?
Old 01-04-2016, 12:23 PM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I'll have to double check today when I put a car up but I'm fairly certain the stock bushing is a pillowball.
Gear_One_Performance is offline   Reply With Quote
Old 01-04-2016, 07:49 PM   #4
twag4
Drives: frs
I just changed all my front and rear suspension bushings. I finished the job on December 30. The outer rear lower control arm bushings on my 2013 were the only cross axis/pillow ball bushings in the car in stock form. Energy makes a complete kit that replaces every single rear bushing not including sway bar bushings. The rear trailing arm bushings are included. The stock ones in mine were rubber. I did not replace the cross axis bushing, as they are even less compromising than polyurethane. The energy kit is a great improvement, and costs considerably less than the individual whiteline pieces. I've used energy bushings in previous cars, and have always had great results from them. For the record I did use the whiteline camber correction bushings in front control arm forward position and whiteline bushings in the aft position on front control arms.
twag4 is offline   Reply With Quote
Old 01-04-2016, 08:41 PM   #5
TRAKRAVN
So just to clarify and make sure I understand this correctly.
The knuckle side of the rear trailing arm is rubber.
The knuckle side of the lower arm (typically used for camber correction with a replacement arm) is a pillow ball bearing.
I wish I could just go and check my car but it's locked away in storage until April.
Old 01-04-2016, 09:43 PM   #6
twag4
Drives: frs
Mine was! Both ends of trailing arm were rubber. I literally swapped them out last week. Outer lower control arm is cross axis bushing from the factory, and inner was rubber. The SPC control arms have cross axis bushings installed on the inner location as well. Both ends of mine have the cross axis bushings on the rear lower control arms now. They have the eccentric adjusters for use at the factory installed cross axis bush on the knuckle. Cross axis is the pillow ball style bushing that is greased and sealed. It is arguably better for all weather street use than a traditional pillow ball or heim joint as it is greased and not directly exposed to the elements. SPC calls their cross axis bushings "x-axis" as their proprietary name. Not bad for $210 for the SPC control arms. Honestly, the ride of my car is improved, while still being much tighter feeling. The suspension articulation is much smoother with all the new bushings. I disconnected the shocks and springs, and the sway bars from the control arms before disassembly. I put the rear back together with all the new bushings before attaching the shocks and sway bars. The comparison was very telling. Much smoother articulation after the swap. Much less springy, which means the springs and shocks handle more of the damping and loading.
adjusting trailing arm puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-11-2025 04:04 AM
Does anyone sell a rear trailing arm rear position bushing? mhiscott Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-15-2015 10:53 PM
Whiteline bushing inserts vs. full bushing replacements mhiscott Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-15-2015 11:45 AM
Suspension Arm Bushing Replacement Question brillo Tracking / Autocross / HPDE / Drifting 0 05-09-2015 08:40 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
