Old 12-15-2015, 08:38 AM   #1
mhiscott
Drives: 2013 FRS
Does anyone sell a rear trailing arm rear position bushing?
I'm ordering a bunch of whiteline bits for my '13 FRS now, and it seems they don't sell a bushing to replace the lower rear bushing in the rear knuckle (hub) which the trailing arm attaches to.
Seems strange as this is a normal plain jane rubber bushing stock.
Whiteline does sell the other spherical bearing that is also pressed into the knuckle, but not the one the trailing arm mates to.
Anyone run into this before when doing all bushings with poly?
Mike
mhiscott is offline   Reply With Quote
Old 12-15-2015, 10:44 AM   #2
twag4
Drives: frs
Energy suspension sells a rear control arm kit that replaces every rear bushing in the knuckle as well as both control arms, trailing arm, and toe arm. Energy part number is 8.3130G for black or 8.3130R for red.
twag4 is offline   Reply With Quote
Old 12-15-2015, 10:53 PM   #3
twag4
Drives: frs
Here is a photo of the bushings, I will be changing every remaining suspension bushing on my car to polyurethane in the next few days. Much of the suspension has already been modified. Yet to be installed I have these bushings, the caster correction bushings from whiteline for the front control arms, new rear lower control arms, I also have the Whiteline roll center correction kit to install, and I am waiting on the other whiteline front control arm bushings to arrive. They are supposed to be here Thursday, then I will get started. The bushings you asked about are somewhere in the photo below...
WTB Rear Shifter Bushing Wyattkb Want-To-Buy Requests 3 07-10-2015 11:54 AM
FS Perrin Rear Bushing CamryDS Engine, Exhaust, Bolt-Ons 1 07-30-2014 12:56 PM
STI Pillowball Trailing and Lateral Links For Rear Suspension Do They Clunk? krayzie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-06-2014 12:47 PM
WTB Rear Shifter Bushing Anthony Want-To-Buy Requests 0 10-26-2013 07:54 AM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 03:48 PM
