Old 12-25-2015, 12:03 PM   #1
coloradobrz
coloradobrz's Avatar
Drives: 15' CWP Limited
Exclamation Blew a ballast?
Was swapping out my headlights for 6000k HIDs from stock. The drivers side light will come on and then turn off after about 20 seconds when the passenger one will stay on. Doubting it's a bulb because they usually aren't intermittent.
Any thoughts?
coloradobrz is offline   Reply With Quote
Old 12-25-2015, 12:40 PM   #2
kberkel
kberkel's Avatar
Try swapping the bulb to the other side? Does the old bulb still work fine if you swapped it back?
kberkel is offline   Reply With Quote
The Following 3 Users Say Thank You to kberkel For This Useful Post:
FRSBRZGT86FAN (12-25-2015), soulreapersteve (12-25-2015), Tcoat (12-25-2015)
Old 12-25-2015, 04:37 PM   #3
ryoma
ryoma's Avatar
it's most likely the bulb. did you buy a cheap bulb? it is really hard to fry the OEM ballast unless you do something extremely wrong lol
The Following User Says Thank You to ryoma For This Useful Post:
Old 12-25-2015, 04:43 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yea, OEM ballasts are really quite good, especially Denso/toyota ones in the brz
Old 12-25-2015, 05:39 PM   #5
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Check your connections are tightly on. Usually when your buying a lower end ebay hid they mix and match bulbs and ballast which will cause loose connections.
ig:Vinshiin
Vincenttam is offline   Reply With Quote
Old 12-26-2015, 01:41 AM   #6
coloradobrz
They were diode dynamics bulbs. One works and one comes on and then goes our after a while. Still goes through the typical HID warm up. Is a bright blue then goes to white and levels. Sits there and then shuts off
Old 12-26-2015, 02:00 AM   #7
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Totaled.
ashtray is offline   Reply With Quote
The Following 2 Users Say Thank You to ashtray For This Useful Post:
acetothermus (12-26-2015), pfaffendorn (02-13-2016)
Old 12-26-2015, 06:25 PM   #8
ryoma
ryoma's Avatar
swap sides on the bulbs and if the problem changes sides, then you have a bad bulb. diode dynamics has good customer service so you will be taken care of. if you have a bad bulb, just contact them and they will fix it for you.
Old 12-26-2015, 08:06 PM   #9
acetothermus
Drives: Flying in a Blue Dream
Originally Posted by ashtray View Post
Totaled.
There's always one guy.... Seriously though this should be the default answer to any question here on the forum.
It's possible the bulb is bad. Try switching it like others have said.
acetothermus is offline   Reply With Quote
Old 12-26-2015, 08:25 PM   #10
FRSBRZGT86FAN
@Diode Dynamics Should chime in here
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Diode Dynamics (12-28-2015)
Old 12-26-2015, 08:31 PM   #11
2pt5RS
Berz
like others have said, swap the bulbs and see if the issue follows. It's unlikely that you blew a ballast. could be a bad bulb, or bad seating of the connectors.
2pt5RS is offline   Reply With Quote
Old 12-28-2015, 10:43 AM   #12
Diode Dynamics
Diode Dynamics's Avatar
Make sure the bulb is seated correctly, that could be causing this issue
Please give us a call for more troubleshooting tips: (314) 205-3033
We are here to help if you need support!
Thanks,
Nick C.
John C.
Diode Dynamics
Old 12-31-2015, 04:17 PM   #13
iConformed
I had the same exact issue, including having DD replacement HID's. Ended up being the bulb, it would go in and out then one day it completely stopped working.
Best to swap bulb to other side, if you have same issue pull it because I left mine for a while and ended up melting a portion of the ballast contact by the time it completely died (still works though). DD's support is great, they were quick to help.
iConformed is offline   Reply With Quote
Old 12-31-2015, 07:23 PM   #14
ryoma
ryoma's Avatar
I don't know why anyone would keep a bad bulb lol. that's just a big safety hazard when driving in the dark. not just for yourself, but for everyone around you since they will only see one headlight and might think you're a motorcycle. I guess it's better than driving with no headlights on though. I still don't understand how people don't notice that they don't have their headlights on lol
SOLD! BRZ HID ballast + OEM sidemarker P3tras Exterior Parts (Aero, Lighting, Etc.) 25 02-13-2016 10:03 AM
Wtb: 55w h11 ballast Tr1huynh Want-To-Buy Requests 0 03-05-2014 07:40 PM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
What would You do if your motor blew? TyperRspec789 Forced Induction 58 07-02-2013 10:54 PM
HID slim ballast Kit for 86 ? TRD_86 Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 03:50 AM
