Old 12-22-2015, 03:23 AM   #1
808BRZ
Drives: 2014 BRZ
Rocford Fosgate P300-10 Install Help
I have never messed with car speakers/subwoofers before so excuse my inexperience. Long story short, I was gifted a P300-10 and figured why not install it in the brz.
[ame="http://www.amazon.com/Rockford-Fosgate-Amplifier-Amplified-Subwoofer/dp/B0197K6F0C/ref=sr_1_2?ie=UTF8&qid=1450772273&sr=8-2&keywords=p300-10"]Amazon.com: Rockford Fosgate P300-10 + Amplifier Wiring Kit 300W Single 10" Amplified Subwoofer Enclosure + 8 Gauge Full Spec CCA Amplifier Wiring Kit for Systems up to 275 Watts: Electronics[/ame]
My main question is, will the below harness connect at the amp instead of the head unit? If I can connect it at the amp, it would be much easier and I wouldn't have to run wires from the hu to the trunk.
http://www.ebay.com/itm/121315480698...%3AMEBIDX%3AIT
808BRZ is offline   Reply With Quote
Old 12-22-2015, 09:43 AM   #2
Chimera
Drives: FRS
so, that appears as if it is made to connect to the front.
it might work on the rear as well, but the rears harness is wired .. special.. theres a really good thread on how to use the rear amp harness.
a good note for what that's going to do is that it appears like that's going to give you full signal out, which if you feed to a sub amp, you will need to be sure to use the amps onboard crossover. Not precisely a problem, just noting it.
I think most people do this by wiring a line out converter to the rear amps wiring harness, however I believe it could also be done with what you have there from the front.
The Following User Says Thank You to Chimera For This Useful Post:
808BRZ (12-23-2015)
FS: Rockford Fosgate 10" sub + amp Avo1789 Audio/Visual, Electronics, Infotainment, NAV 4 10-23-2015 08:54 PM
Rockford Fosgate P300-10 powered sub review robwbright Electronics | Audio | NAV | Infotainment 20 09-13-2015 02:14 PM
Rockford Fosgate P3D2-10, PowerBass 400.1 $225 Sub install kit Hyper4mance2k Audio/Visual, Electronics, Infotainment, NAV 1 06-06-2015 01:39 AM
(DELETE) FS: Rockford Fosgate PBR300X1 amp NEW in box migueralliart Audio/Visual, Electronics, Infotainment, NAV 1 03-02-2014 12:26 PM
Rockford Fosgate 500W Amp finch1750 Audio/Visual, Electronics, Infotainment, NAV 2 03-26-2013 10:16 AM
