Old 03-26-2014, 06:25 PM   #1
FRSHunter
Drives: Asphalt FRS
Something wrong with my DRL's?
I installed some JDM headlamps into my FRS. I made sure to remove the DRL Resistor at the bottom because the JDM HID's do not require it. Plugged it in with the Harnesses made from a user here and everything works but the DRL. I can get Low beams, High beams, but no LED DRL's to work.
I also went back and reverted it and places the halogen headlamps + the resistor back on. Everything works except the DRL. Even the high beams which uses the same bulb works. I thought it might be the DRL fuse but users stated that removing that fuse would also remove high beams altogether as well.
Not exactly sure what is wrong. Anyone have any clues as to whats happening?
FRSHunter is offline   Reply With Quote
Old 03-26-2014, 06:40 PM   #2
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
You didnt happen to have your DRLs turned off through techstream did you?
lickitysplit is offline   Reply With Quote
Old 03-26-2014, 06:41 PM   #3
FRSHunter
Drives: Asphalt FRS
Nope, day before installation they were working fine.
Old 03-26-2014, 07:46 PM   #4
FRSHunter
Drives: Asphalt FRS
Update put everything back to OEM and everything works fine. Either my LED's in THREE JDM headlights are broken or the harnesses are bad.
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
This must be wrong... Ongor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-23-2014 11:29 AM
HELP! WRONG GAS IN CAR nabil_frs CANADA 9 05-06-2013 03:49 PM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
