Old 12-11-2015, 11:21 PM   #1
swarb
How can I reduce noise from my signal?
So I installed the 4 channel x 45watt Alpine ktp-445a on my Brz a while back. I am powering the front door speakers at 45 watts.
Gain is turned about halfway so door speakers a louder than the dash speakers(sounds harsh/glaring).
With the volume at 0 on the head unit, it sounds like a fan is on. It is bothering me quite a bit.
I am using the factory wired ground.
How can I reduce the noise?
Should I make a chassis ground? Should I keep the wired ground connected also to have 2x the ground?
Filters?
Also, how do I turn off the head unit completely? I can turn off the screen, or turn off the input, but the head unit is still on and the noise is still there. Ideas?
Old 12-12-2015, 03:26 AM   #2
crash.1340
BRZ FNG
crash.1340's Avatar
Drives: 00 Civic LX/CWP or GBS BRZ someday
Speaking from personal experience with the KTP, you can try making a chassis ground, you can also try making some sort of ground that attaches to the head unit somehow, that attaches to the same chassis ground you use for the amp. Make sure all bare wires are totally insulated or covered, that they don't touch the chassis at all, even the amp inputs.
crash.1340 is offline   Reply With Quote
Old 12-12-2015, 12:50 PM   #3
ARTBRZ
Aloha!
ARTBRZ's Avatar
I commented previously based on skimming what you wrote. Definitely not the cause when I read through it.
ARTBRZ is offline   Reply With Quote
Old 12-16-2015, 08:57 PM   #4
swarb
bump for more ideas or how to turn off the head unit completely.
Old 12-22-2015, 01:26 AM   #5
bumppinKota
Drives: FRS!!!
Not usually a problem for lower watts but if you are using RCA cables and they are near the power cord it may cause interference. Just something else to look at if the ground doesn't fix it.
bumppinKota is offline   Reply With Quote
Turn signal stalk making weird high pitched noise. FRS-Learner Issues | Warranty | Recalls / TSB 6 11-07-2015 08:54 PM
Top hat spacers to reduce NVH? swarb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 02-04-2015 07:52 PM
Temporary Ways to reduce exhaust noise? OnionTou Engine, Exhaust, Transmission 35 05-26-2014 12:46 PM
How to reduce window noise with windows down? Sphirit Cosmetic Modification (Interior/Exterior/Lighting) 5 05-21-2014 09:54 PM
what's your solution to reduce the wheel well gap? chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-14-2013 09:25 AM
