Old 12-07-2015, 07:39 PM   #1
joey999
Drives: frs
What wheels/tire combo should i get?
Thinking of keeping stock suspension for a while however i want to change the wheels/tire.ls. How is 18*8.5+38 squared on a stock suspension setup? Will it fit easily on stock struts and no scrubbing? What tires should i run?
Anyone have any pics of it?
joey999 is offline   Reply With Quote
Old 12-07-2015, 07:58 PM   #2
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I don't think the sizing will be an issue. As for the tires, what kind of driving are you doing?
Lynxis is offline   Reply With Quote
Old 12-07-2015, 08:15 PM   #3
joey999
Drives: frs
Just daily mainly
Old 12-07-2015, 08:43 PM   #4
Lynxis
Lynxis's Avatar
You're in New York? If you are going to be driving it in the winter, then any decent snow tire will be good. If you're looking for something for the rest of the year, I hear Continental Extremecontact DWS is a good all season tire or Michelin Pilot Super Sports are also good. A 245/35/18 will be a good size for an 18x8.5 rim.
Old 12-07-2015, 09:25 PM   #5
joey999
Drives: frs
So you think with stock suspenion stay 18*8.5 rim? How about 18*9.5+38v
How would that go with stock suspension. Dont want scrubbing etc
Old 12-08-2015, 12:45 AM   #6
Lynxis
Lynxis's Avatar
18x9.5 might rub depending on the offset, camber adjustment and tire. There isn't really any benefit to running such a wide wheel on the street anyway so I'd suggest running the 8.5.
Old 12-08-2015, 02:02 AM   #7
joey999
Drives: frs
Might rub ehhhh
Old 12-08-2015, 02:29 AM   #8
swarb
Originally Posted by joey999 View Post
Might rub ehhhh
It will be very close. 1/4inch or 5mm, less on some cars. You can run a spacer, but the wheels already poke out. 18x8.5 +38 and 245/35-18 is a good setup with stock suspension.
The Following User Says Thank You to swarb For This Useful Post:
chaoskaze (12-09-2015)
Old 12-08-2015, 03:17 AM   #9
joey999
Drives: frs
that setup wont rub and affect the stock struts etc? How does it look? Agreesive look?
Hard to decide between that and 17*9s wheels
Old 12-08-2015, 03:25 AM   #10
swarb
Won't rub. 17x9's poke out more and are closer to rubbing, especially +42/45 offsets. Search, there are plenty of pics around.
17's for cheaper tires, lighter, more bubbly meaty tire look.
18's for big wheel and thin tire look.
If you are keeping the stock suspension, 17's are more factory looking and 18's are more dub or concept looking.
Old 12-08-2015, 06:50 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
One can consider also 16" for even cheaper tires, even lighter wheel+tire package and more meaty look then 17". From reviews, one also gets more comfort when DD, w. slightly less sharp turn-in. For 16" it's worth to see how it will look first. Some wheels look ok-ish in 16", some - not (eg. i didn't like look of TE37SL @16", while i liked it at bigger sizes).
Old 12-08-2015, 12:19 PM   #12
Lynxis
Lynxis's Avatar
Agree with the statements that a 16 or 17 inch rim looks better on stock suspension. I think 18s look sort of funny if you aren't lowered:
The Following User Says Thank You to Lynxis For This Useful Post:
Old 12-09-2015, 04:53 PM   #13
vividracing
vividracing's Avatar
Would this work for you? Or something like this?
https://www.vividracing.com/catalog/...150726362.html
-Mike
vividracing is offline   Reply With Quote
Old 12-09-2015, 06:01 PM   #14
swarb
^such a bad setup. Don't even consider it. Just trying to make sales... the 18x8.5 is ok, offset is a little high. The 19x9.5....
Can you stagger this tire combo? Brody602 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-13-2014 08:12 PM
Anybody taken their wheel/tire combo off their FR-S and... cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-05-2013 02:47 PM
Functional tire combo tintumz22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 02-06-2013 01:12 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 09:33 AM
