Old 12-04-2015, 03:23 PM   #1
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Brake Pad Wear?
I'm at 45k miles and the dealer said I still have 60% left on the front pads and 40% on the rear. I've never had pads last this long on a car before. Granted I've also never had a car this light that doesn't require braking for most turns either Just curious if others are experiencing the same.
rapidcars is offline   Reply With Quote
Old 12-04-2015, 03:36 PM   #2
swarb
Yes, some people have gone to 100k+. If you do a lot of highway driving it helps.
Old 12-04-2015, 04:49 PM   #3
extrashaky
Drives: 2014 BRZ Limited
It also helps if you drive a manual and use engine braking. I'm at 48K miles on mine. When I was in for the 47.5K service, the service tech didn't give me a percentage but said they had plenty left.
I'd love to see the numbers comparing average brake life between autos and manuals in this car.
Old 12-04-2015, 04:56 PM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I just checked my pads a few weekends ago after doing my 35k oil change and also noticed this. Is it weird that the rears are wearing out before the fronts? In all my previous cars, I've always had more wear in the fronts.
Old 12-04-2015, 05:52 PM   #5
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Were all your other cars fwd by any chance? I am in no way an expert on brakes but one would deduce that the wheels powered by the drivetrain would put more strain/usage on the brakes.
Also the fact that the car's center of gravity sits so low and that the engine/tranny sit so far back make the car quite balanced vs other front engine cars that have the weight bias more towards the front meaning more strain on the pads when braking.
Then again I could be all wrong about all of this
fumanchu1 is offline   Reply With Quote
Old 12-04-2015, 06:09 PM   #6
BigFatFlip
BigFatFlip's Avatar
Not particularly. I've seen the same on my tacoma (front engined rear driven) as well as my wrx (front engined awd). I've always thought that the fronts were always working harder due to weight transfer during braking, granted this car is probably the lightest car I've owned. Perhaps the traction/stability control plays a part in it? I know when it kicks in, it uses the rear brakes to keep things in check, but I hardly ever set that off (usually off on trackday/autox)
Old 12-04-2015, 06:20 PM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I bought my car used so I don't know if the brakes have been changed etc. but when I took the car in for 30k service the tech told me that they look brand new and they felt aftermarket (he drove the car after the service) they squeel ever so slightly. Also, I've always had more brake dust from the rear pads than the front. I agree with @BigFatFlip that it's probably from the traction control system.
Instagram: trevor.parque
Old 12-04-2015, 06:21 PM   #8
strat61caster
strat61caster's Avatar
43k and I bought new street pads because I was just plain tired of OEM, nothing wrong, probably have another 10k-30k miles left in them but they stop like crap ever since I overheated them. So, OP's life is reasonable, light car + long lasting compound.
Hell just found out from another post that some places offer 'lifetime brakes', literally they're supposed to last the life of the car. I wonder if they can even engage ABS with good tires equipped...
Brake wear has to do with traction to the road not power to the wheels, fronts will always have more stopping power/use more material/generate more heat because of the way weight transfers upon slowing the car down. FWD may have more weight over the front end creating more traction and thus more brake wear, but not much more than a similarly setup front engined rear wheel drive car with similar suspension geometry.
Unless ABS/Traction Control is in play.
ineedyourdiddly
Old 12-15-2015, 02:42 PM   #9
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Lots of burnouts?
Fishbed77 is offline   Reply With Quote
Old 12-15-2015, 07:29 PM   #10
Imrac
Drives: 13 SWP BRZ Prem
I bet your stability control pumps the rear more the the front.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 12-15-2015, 09:21 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep. The nannies working overtime.
Old 12-15-2015, 10:29 PM   #12
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Yup. Everytime your rear wheels would normally lose traction, the stability control kicks in by using the rear brakes.
carma143 is offline   Reply With Quote
Old 02-04-2016, 11:38 AM   #13
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
Is it me or anyone else having a problem determining what percentage of the brake pads are left on the BRZ? I don't have any issues with my other cars but I just don't know where to look even with the wheels off on the Subie. Is it through that tiny slit in the calipers?
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 02-04-2016, 12:06 PM   #14
kch
Senior Misanthrope
kch's Avatar
yeah, or you can just swing the calipers up. they're super easy to remove.
Possible clutch wear? Romanov Engine, Exhaust, Transmission 6 06-11-2015 09:12 PM
Abnormal rear brake wear 2013 w/ 31,700 miles Gen3MR2 Issues | Warranty | Recalls / TSB 13 04-02-2015 01:44 PM
How to Gauge Brake Pad Wear? tez2013 Tracking / Autocross / HPDE / Drifting 7 07-08-2013 11:19 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
