Old 07-06-2013, 09:38 PM   #1
tez2013
How to Gauge Brake Pad Wear?
Is there a way to tell how much pad you have left without taking off the wheel / caliper?
I used to be able to do this using a tiny mirror and a flashlight on my other car; however, on a first try I wasn't able to see a whole lot through BRZ's caliper. Anyone have any suggestions?
tez2013 is offline   Reply With Quote
Old 07-07-2013, 02:53 AM   #2
troek
troek's Avatar
Drives: 2012 Toyota 86
most pads have a warning indicator that will rub and make noise when ur pads are worn too much
Old 07-07-2013, 02:05 PM   #3
Look at the inside of the caliper, between the caliper and the bracket. You should be able to see the pad.
Try to gauge the TOTAL thickness of the pad, including the backing plate itself. Your flashlight should cast a shadow of the backing onto the rotor. If the shadow is more than 2mm or so, you're good. Alternatively, if the TOTAL thickness appears to be more than 7mm, you're good.
A new pad has roughly 9-10mm of pad material, and the backing is another 5mm.
Old 07-07-2013, 02:10 PM   #4
tez2013
This is really helpful, thanks! :happy0180:
Old 07-07-2013, 08:04 PM   #5
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I measured my Hawk HP+ today and they have about 7-8mm of pad material left after 2 track days. I guess OEM tires don't really put that much stress on the pads lol. I've been searching around but can't find what is the thickness of a brand new HP+ pad. I'd like to know how much I've worn them down.
raul is offline   Reply With Quote
Old 07-07-2013, 09:19 PM   #6
@raul: looks like you've used about 30% of them. If you get stickier tires (or as you start getting more comfortable with the car), you're going to need a dedicated set of pads. We have several options
Old 07-07-2013, 10:10 PM   #7
troek
troek's Avatar
CSG Mike, in the past ive used the center groove thats used to vent gasses as kind of a wear indicator. is that somewhat accurate?
Old 07-08-2013, 11:19 AM   #8
Certainly is, but not all pads have that center groove
How much camber wear from Eibach Pro Kit slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-23-2013 07:25 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 04:25 AM
