Old 12-03-2015, 07:20 PM   #1
bspec
A man
Drives: 14 BRZed
Nameless Header and Off-The-Shelf Overpipe Fitment
Salutations,
Recently pieced together a head-back exhaust:
Nameless header
PLM OP
PLM FP
HKS Hi-Power L cat back
The PLM overpipe contacts the OEM sway bar during assembly, and was probably 1/2" short of mating to the front-pipe, with the exhaust hangers at full stretch. Factory overpipe fits and length is correct, so it's back on for the time being, but sounds awful and is likely leaking at the header flange.
Long and short of it (no pun intended) - Can someone confirm fitment of an off-the-shelf overpipe with nameless header, that doesn't require sway bar shimming or stiff engine mounts?
I'd love to chuck the PLM OP/FP for JDL, but I just need an overpipe that can be sourced quickly.
Thanks
bspec is offline   Reply With Quote
Old 12-03-2015, 07:54 PM   #2
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by bspec View Post
Salutations,
Nameless header
PLM OP
PLM FP
Thanks
I used to have a Nameless header and I used a 2.5" JDL overpipe with a 3" flange on the header side and a 2.5" flange on the frontpipe side. This worked great for me and I didn't have any fitment issues. I no longer have the header, but I still have the overpipe if you're interested. I sent you a PM.
jprice130 is offline   Reply With Quote
The Following User Says Thank You to jprice130 For This Useful Post:
bspec (12-20-2015)
Old 12-04-2015, 06:38 PM   #3
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I don't understand why you got the nameless header and the company that ripped them off for OP/FP. I would have expected all cheap or all nice
http://www.ft86club.com/forums/showt...ameless+header
back to your question, the local car with full nameless works fine no fitment problems. everything ends in the stock locations
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
go_a_way1 (12-04-2015)
Old 12-04-2015, 06:40 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
he makes a good point?
Old 12-19-2015, 03:28 PM   #5
bspec
A man
Drives: 14 BRZed
Right, nameless parts are made to order in most cases, so not exactly off-the-shelf. Again, it came down to time constraints. I thought I could deal with the poor header to OP fitment until I did either a custom OP/FP or I came to grips with the JDL/Nameless price tags for those pipes, but 3 destroyed gaskets later and...
I ended up picking up the cat-back rather unexpectedly and wanted to knock everything out at once.
The custom JDL overpipe I picked up from @jprice130 fits well, although I did have to raise the engine to wedge in the 3" flange.
3" JDL overpipe for Nameless header? xjohnx Engine, Exhaust, Transmission 19 06-16-2015 11:00 PM
Nameless header + overpipe fitment issues RiskyTrousers Engine, Exhaust, Transmission 105 05-25-2015 01:32 AM
Off the shelf OFT Tune Tomei EL Header speeddemon Software Tuning 3 01-19-2015 09:56 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Overpipe fitment? IAmNotTheDriftKing Engine, Exhaust, Transmission 14 10-05-2013 02:45 AM
