Old 01-18-2015, 12:16 PM   #1
speeddemon
Drives: Scion frs
Off the shelf OFT Tune Tomei EL Header
Does anyone know if there is an off the shelf OFT tune for a Tomei EL header? If not, is there another off the shelf tune that I could run that would work well if I go with this header choice?
speeddemon is offline   Reply With Quote
Old 01-18-2015, 12:22 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Stage 2. I don't recall seeing graphs of this header, but the ones we have seen seem to squeeze out a little more power here and there when custom tuned, no more. Enough that as an OTS tune its just about right.
Old 01-18-2015, 01:30 PM   #3
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
As long as you're using the oft stage 2 el it should work no problem.
Stealthy is offline   Reply With Quote
Old 01-19-2015, 09:56 AM   #4
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I have looked at both the EL and UEL OFT stage 2 tunes. There isn't a huge difference so between one manufacturer of a EL header to another EL I don't think there will be any difference. There is more a difference from car to car then EL header to EL header.
Toyota John is offline   Reply With Quote
The Following User Says Thank You to Toyota John For This Useful Post:
speeddemon (01-19-2015)
Ft86speedfactory UEL header vs, Tomei Expreme UEL Header WallsAndFoundations Engine, Exhaust, Transmission 47 06-24-2015 04:50 PM
FS: Tomei EL Header harkbrz Engine, Exhaust, Bolt-Ons 1 02-13-2015 03:15 PM
TOMEI UEL vs. EL headers (w/stage 2 OTS tune) UrmyboyBLUE Engine, Exhaust, Transmission 42 10-25-2014 03:16 AM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
FS: Tomei UEL Header (WRX) [deleted] Miscellaneous 0 03-19-2013 10:58 PM
