Old 12-02-2015, 02:16 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Meaty tires suggestions for 17x8 35?
I'm new to aftermarket tires so I'm sorry if this has been asked before.
I really like the meaty tire look.
Right now I'm running 225/45/17 on my 17x8 35. They aren't meaty enough for me even though they're a bit larger than stock.
I'd like to get the meatiest without rubbing on stock suspension and without lowering (will lower maybe later if I'm still not happy) because I don't want to lower it unless it's a last resort.
Any suggestions and pictures?
Thanks
YamahaR86 is offline   Reply With Quote
Old 12-02-2015, 02:31 PM   #2
swarb
245/40-17 Look up specs on tire manufacturers website on what size rim they recommend and the width ranges. Also go under the car and inspect if you have room for approximately 10mm inside and 10mm outside for clearance. You should be fine.
The Following User Says Thank You to swarb For This Useful Post:
YamahaR86 (12-03-2015)
Old 12-02-2015, 05:57 PM   #3
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
I've had 245/40 on that spec RPF1 and it clears with no issue at stock height and lowered 20mm, although stock height it looks a tad pokey.
Your only problem will be steering feel as it will get sloppy since the wheel is so much narrower than the tire. I was getting more understeer at the limits.
blue cat is offline   Reply With Quote
The Following User Says Thank You to blue cat For This Useful Post:
Old 12-03-2015, 02:37 PM   #4
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Thanks. This is the setup I may go with then. If it's noticeable poke that bothers me I'll go with TRD Springs or RCE Yellows for a slight drop.
I don't think I'll be taking it to the limits, just daily driving and more for appearance. Think I'll get a different set of wheels for autocross or autox when I try to
The Following User Says Thank You to YamahaR86 For This Useful Post:
MaxRED13 (12-04-2015)
Old 12-04-2015, 12:24 PM   #5
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Drives: Scion FR-S Red//MT
The TRD springs lower slightly more than the race springs. I would say the TRD springs were about a 30mm drop. Depending on the tire too, the tire itself may run wider. For SCCA I have seen 255/40 Dunlop direzzas zii on a 17x8 et35. Those tires tend to run a bit wider, and also had about 1.5 of camber to get the wheel to tilt in a bit.
MaxRED13 is offline   Reply With Quote
Meaty Tire Thread Jive Turkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2552 12-28-2025 10:06 AM
New Rims and Tires! suggestions?? Chase1996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-27-2015 10:58 PM
any possible issues with 17x8 +32 on 245/40 tires? dejxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-24-2015 03:42 PM
My Meaty FR-S Build JarredH Member's Car Journals 1 06-02-2014 08:10 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
