Old 11-05-2014, 01:03 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
any possible issues with 17x8 +32 on 245/40 tires?
Do you guys think i would have any issues running this setup? Droped on Eibach Pro-kit (around 1"). Here in Brazil and Argentina roads suck bad, so im trying to get a setup with 17 inch wheels and slightly meaty tires. Wheels options are little too... found a 17x8 +32 Volk TE37 replica that would do the job.
Any help is appreciated! thanks!
dejxx is offline   Reply With Quote
Old 11-05-2014, 01:20 PM   #2
jdmblood
jdmblood's Avatar
Drives: white subaru brz
I'm running 17x8 +45 running 225/45 dropped 2" on coils. I have no problems and I don't reccomend running 245 on 8width. I believe the tire will bulge. 245 was meant for 9"
jdmblood is offline   Reply With Quote
Old 11-05-2014, 01:31 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You are fine to run a 245/40 on an 8. I am running 245/40 MPSS on 7.5 inch wide. Cheaper tires may/will buldge. My Michelin tires look good, not pinched. I think that the offset may cause the front to rub on the fender with 245. camber bolts may be enough clearance. I would go 225/45 for that offset.
yeah, they are dirty.
Old 11-05-2014, 01:33 PM   #4
dp1
driving smoother faster
Drives: Sold
Read the tire-size-specific instructions for minimum/optimal/maximum rim size, and remember to stay as close to the overall tire diameter as stock.
dp1 is offline   Reply With Quote
Old 11-05-2014, 03:29 PM   #5
dejxx
dejxx's Avatar
Drives: FT-86
Thanks for all the answers. I do travel a lot with the car, but i want a more aggressive look (meaty), that's why i was wondering about 245/40. Maybe ill drop to a 235/40-45 depending on how it looks and if the ride isn't compromised. i use Yokohamas R.Drive, decent tires on 225/45/17.
Old 11-05-2014, 03:36 PM   #6
DarkSunrise
DarkSunrise's Avatar
235/40/17 is fine on an 8" wheel, but will compromise ride slightly since you get less sidewall than stock.
2022 BRZ Build
2013 FR-S Build
Old 11-05-2014, 04:00 PM   #7
dejxx
dejxx's Avatar
Drives: FT-86
how about 235/45?
Old 04-19-2015, 01:48 AM   #8
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
What's your wheel offset for this setup? It looks pretty flush. Any other suspension mods?
jimmillion is offline   Reply With Quote
Old 04-24-2015, 03:42 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+38 offset. Suspension mods include Eibach ProKit Springs. (and an alignment)
jimmillion (04-26-2015)
Enkei RC-T4 17x8 +48 with Advan 245/40/R17 tires Parikh1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-01-2014 12:41 PM
*SOLD* 17x8 RPF1's with 245/40 PSS tires (Virginia) UncleFester Wheels and Tires 3 09-11-2013 03:58 PM
FS: SOCAL: 17x8+30 Rotiform NUE w/ tires!!! mr. slim Wheels and Tires 6 05-09-2013 02:55 PM
What tires for 17x8 +42 Work Emotion CR Kai itisthumper Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-20-2013 05:54 PM
FS/FT: Volk TE37 17x8 with Tires Tanuki Wheels and Tires 4 12-11-2012 01:39 PM
