Southern California SoCal
Old 12-02-2015, 01:25 AM   #1
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Brake Pads Upgrade - Shop Recommendations in OC?
Hey everyone!
Been a while since I posted on this forum, welp here goes.
Recently I noticed that my front driver side brakes are making a grinding noise whenever I slightly depress the brake pedal. My front brakes are probably around 30-40%, so I figured it was time for an upgrade. I purchased the WinMax W2 front pads for my BRZ. Here are some questions -
1. Can anyone recommend a cheap but good quality place that will swap out the stock pads for me?
2. Is it necessary to re-surface the rotors & drain the brake fluid with a brake pad upgrade?
3. Can I leave the rear brakes stock since they are generally used less?
Thanks guys!
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 12-02-2015, 02:08 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
1, pretty much any shop would do it. If you have basic tools or space to work at you can do it yourself. Brakes are pretty easy. That's if you have the tools and space to work on.
2. Not really. If there are deep grooves or the pads are worn out highly uneven, or are too thin below spec then yes. As for the fluid, if it's been a few years or you reached the service interval mileage then it's time.
3. Yes. But it might be a good idea to check the ware on them. If you haven't changed them in a few years it might be time. Depends on what you see.
The Following User Says Thank You to Mr.ac For This Useful Post:
KelvinBRZ (12-02-2015)
Old 12-02-2015, 07:30 PM   #3
Mindering
Minty Fresh
Drives: Scion FR-S
http://www.arcaneconcepts.com
424-571-9577
Can get a nice selection of brakes, solid work is done without an insane price tag.
Mindering is offline   Reply With Quote
The Following User Says Thank You to Mindering For This Useful Post:
Old 12-02-2015, 08:04 PM   #4
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
hello, i can help - "DIY DAY"
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZtoni For This Useful Post:
KelvinBRZ (12-02-2015), KR-S (12-02-2015)
Old 12-02-2015, 09:11 PM   #5
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Thanks for all your input!! I'm about 40K miles in - it's about that time for a brake change.
GBS Mafia
Old 12-02-2015, 09:47 PM   #6
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
This. I'm looking to mod my car and brake pads are a definite future upgrade. Bring your car over to DIY Day for the benefit of me and yourself - but mostly me.
Old 12-03-2015, 01:42 PM   #7
Originally Posted by KelvinBRZ View Post
Hey everyone!
Thanks guys!
1. I recommend you spend the money on tools; the first time you do this you'll already have broken even on a floor jack, jack stands, and a basic set of tools.
2. Nope
3. I recommend you use the same pad compound front/rear. The car is designed this way, and you should stick to that unlses you have a very, very specific need/reason to not do so.
KelvinBRZ (12-04-2015), KR-S (12-03-2015)
Old 12-03-2015, 02:24 PM   #8
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
2. Nope
definetly #1
once u do your first repair its going to save u some money in the long run
Flex Fuel Turbo BRZ
Old 12-03-2015, 03:49 PM   #9
shellslinger
Drives: Whiteout FRS
I'll help you change them out as long you bring me back some Woodstock's Pizza we got a deal!
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Recommendations for plug and play speaker upgrade? irocz0r Electronics | Audio | NAV | Infotainment 10 09-07-2016 02:32 AM
Recommendations for track pads better than PMU HC800+? DarkSunrise Tracking / Autocross / HPDE / Drifting 32 03-10-2016 03:21 PM
FS: GT spec brake upgrade package (front disc & pads) Fizz Australia Classifieds 0 05-28-2014 01:33 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
