Old 11-29-2015, 04:52 PM   #1
diBreezy
diBreezy's Avatar
Drives: 2013 Raven FRS
HELP! Tried using OFT. Now car won't start!
I'm in a full blown panic. I do not know why this happened. I tried resetting the battery. Nothing. The OFT says the Stage 1 tune is in my ECU.
I road tripped down to North Carolina. Now I can't leave!
I attempted to contact Open Flash via email. They have not yet responded.
diBreezy is offline   Reply With Quote
Old 11-29-2015, 04:58 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Did you try flashing back to the stock tune?
Old 11-29-2015, 05:01 PM   #3
diBreezy
diBreezy's Avatar
Yes. Now it says Original.
EDIT: And the car won't start. Also, the OFT does not turn on when I turn the key to ACC
Old 11-29-2015, 05:02 PM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
And your car still won't start?
Old 11-29-2015, 05:03 PM   #5
diBreezy
diBreezy's Avatar
Correct.
EDIT: It also says "Vin not locked" under INFO.
Old 11-29-2015, 05:04 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My car has done this when I tuned with ECU Tek. It still cranks right?? Try to give it some gas when you crank it
Edit: I should also add that it will run like crap for the first km or so until the ECU learns. IDK this happend to me but it happens haha
Old 11-29-2015, 05:04 PM   #7
JB86'd
JB86'd's Avatar
Drives: JAWS
Try calling Openflash on the phone
Old 11-29-2015, 05:08 PM   #8
diBreezy
diBreezy's Avatar
The car does not even crank.
OMG Please give me the number!
Old 11-29-2015, 05:10 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Shit it doesn't even crank??
Old 11-29-2015, 05:10 PM   #10
diBreezy
diBreezy's Avatar
Tried calling. "Limited phone support during the holiday weekend"
Old 11-29-2015, 05:11 PM   #11
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You're going to have to be more clear.
You went on a road trip.
When you got there you decided to flash your car.
Then immediately your car doesn't work.
Or you flashed.
Then drove the car successfully.
Then it stopped working.
Old 11-29-2015, 05:11 PM   #12
diBreezy
diBreezy's Avatar
Emphasis on "full-blown panic"
Old 11-29-2015, 05:12 PM   #13
diBreezy
diBreezy's Avatar
Or you flashed.
The first one. Road trip>Attempt>Car doesn't crank
Old 11-29-2015, 05:14 PM   #14
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Where did you get this OFT and why did you first try using it so far from home?
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Chrisgalactic (11-30-2015)
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Where did you start with your FR-S/BRZ jeepmor Scion FR-S / Toyota 86 GT86 General Forum 43 04-10-2014 01:39 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
