Old 11-27-2015, 01:34 PM   #1
Cedars
Drives: gt86
What's the normal idle range on the RPM?
Hi guys,
My mistress registers 700 rpm on idle instead of the 1000 rpm I've seen on every single car I've owned. Is this normal or is she totaled
Cedars is offline   Reply With Quote
Old 11-27-2015, 01:38 PM   #2
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Originally Posted by Cedars View Post
Hi guys,
Normal after warm up.
wireman957 is offline   Reply With Quote
The Following User Says Thank You to wireman957 For This Useful Post:
Cedars (11-27-2015)
Old 11-27-2015, 01:38 PM   #3
jvincent
jvincent's Avatar
Normal for a stock car.
The Following User Says Thank You to jvincent For This Useful Post:
Cedars (11-27-2015)
Old 11-27-2015, 01:42 PM   #4
Again normal
But...
Can fluctuate as much as 200 when the air conditioning is running. This is a normal thing with these and not an issue so don't freak out when it happens.
Cedars (11-27-2015), FRSBRZGT86FAN (11-27-2015)
Old 11-27-2015, 01:52 PM   #5
Cedars
Drives: gt86
One more thing, I have a sticker that says next oil change at 15,000 kms, I have 4000 kms on it now, last oil change was the 1000km, is that what you guys do? I normally change it every 5000kms on other cars. 15,000 on a sport engine. Hmmm, no way I think. No idea what oil the dealer used. I'm just gonna change it at 10,000 kms.
Old 11-27-2015, 01:52 PM   #6
strat61caster
strat61caster's Avatar
Read the manual.
ineedyourdiddly
Tcoat (11-27-2015)
Old 11-27-2015, 01:55 PM   #7
The 15K is required but of course more often is better.
Like Strat said you can get a pile of info from the manual. You will even learn things you didn't know you had a questions about.
Old 11-27-2015, 01:59 PM   #8
Cedars
Drives: gt86
Today I took her on some windey mountain roads, it was an amazing ride, but I'm still a bit new at driving a gt and unsure of what it will do at high speeds on corners, it feels so Godamn light (which it is), and wind tends to buffet it a bit, do u think I should be more confident and go for it? Michelline stock tires. I'm a front wheel driver with fast cars( crx, celica 91, scirocco) and to be honest rear wheel feels a bit loose on corners compared to those cars, if it breaks free on a corner you think I can bring her back easily or is she going to cause a drama?
Old 11-27-2015, 02:04 PM   #9
Cole
Not a troll
Cole's Avatar
post ur rpms at the start
The Following User Says Thank You to Cole For This Useful Post:
Tcoat (11-27-2015)
Old 11-27-2015, 02:07 PM   #10
Cedars
Drives: gt86
I've never seen a car that gets its oil changed every 15,000 kms tbh, that's the standard huh, ok rpm idle 700 normal, oil change every 15k normal, I think I know what this car is, it's a spaceship
Old 11-27-2015, 02:08 PM   #11
FRSBRZGT86FAN (11-27-2015), jawn (11-27-2015), STV3 (11-27-2015)
Old 11-27-2015, 02:12 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I probably wouldn't try much until you are used to it. The stability nannies help out quite a bit but don't get overconfident. Get used to the car or else you will be the next accident thread.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Cedars (11-27-2015), Tcoat (11-27-2015)
Old 11-27-2015, 02:13 PM   #13
Cedars
Drives: gt86
Start is always at around 1500 rpm depending on weather, within a minute or two starts to go down once it warms up. But the idle is always at 700 RPM at traffic lights etc.
Old 11-27-2015, 02:17 PM   #14
jvincent
jvincent's Avatar
Just FYI, the rpms at start is a SquadRogue reference.
Find the thread, grab a beer, and enjoy.
Tcoat (11-27-2015)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Oil Pressure Range blackfireball5 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 135 12-10-2019 08:26 PM
Engine Idle... Is this normal? Premium 615 Engine, Exhaust, Transmission 5 08-28-2015 12:47 AM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 10:27 AM
Can't decide, is my idle problem or normal? ultra_frs Issues | Warranty | Recalls / TSB 5 05-21-2013 02:49 PM
