Old 08-19-2013, 03:03 AM   #1
goli5oda
Drives: Firestorm FR-S
Unhappy Mid range really lacking
I got my firestorm FR-S today that came with the 2014 scion display audio. I found the speakers sounding really tinny. Mid range was really lacking unless I cranked the volume to 25-30. Is there an equalizer setting that I could use to boost the mid range? Do these speakers start sounding better as they break-in?
(comparing to the audio in my Honda odyssey)
goli5oda is offline   Reply With Quote
Old 08-19-2013, 03:05 AM   #2
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
Check the settings to make sure it's set for "FR-S".
MY13FRS is offline   Reply With Quote
Old 08-19-2013, 03:08 AM   #3
SigmaHyperion
Drives: 2013 SWP BRZ Limited
Overall, the speakers and sound are really, really lacking. So don't expect some magical improvement in them over time. I'm not an audiophile in the least. Couldn't give a flyin' fart. And even I noticed in seconds that the sound was horrible and have considered upgrades.
SigmaHyperion is offline   Reply With Quote
Old 08-19-2013, 03:10 AM   #4
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I listen at 25-30 anyway so I guess I just don't notice. In terms of an equalizer you can toggle between the three choices of Hear, Feel, and whatever the third is I don't recall (Natural?). I leave mine on Feel and crank the treble/bass to usually 4. Keep in mind you need to set the treble/bass option for each audio type. So if you set it while listening to the radio and then switch to bluetooth, you have to set it again because it defaults to 0 for each type (CD, AUX, Radio, USB, etc) until you adjust it. Once they're all set they stay.
Yeah I'm sure it's not amazing compared to expensive audio systems, but for free I feel it's pretty damn good. The BRZ crew only get a 196w so it's worse for them (though they do get a proper equalizer).
oldpueblo is offline   Reply With Quote
Old 08-19-2013, 10:27 AM   #5
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
The problem is that the factory amp powering the 6.5's in the doors is terribly weak, and those speakers are your only source of bass in the car. There's not much you can do with what you're given from the factory to make things better.
There are several upgrade routes to consider depending on your budget. Personally I bypassed the stock amp using this method and I'm quite happy with the results. It's not a subwoofer but it really helped.
http://www.ft86club.com/forums/showthread.php?t=42239
Swapping the door speakers with another 2ohm aftermarket speaker (Infinity or JBL are 2ohm)
Adding a sub would be relatively simple since the stock HU has sub pre-outs but you'd have to run power and RCA cables.
If you have some more money to throw around the OEM audio 400 ($1200) is getting very good reviews from everyone and the bonus is that it's plug and play.
There's also the full custom route if you're so inclined.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Safe/reliable amount of Hp range for BRZ Howardwei Forced Induction 74 07-29-2013 03:50 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 04:04 PM
Lets talk about FRS lacking fog lights, why does everyone want them? post_break Scion FR-S / Toyota 86 GT86 General Forum 35 12-13-2012 10:39 AM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 02:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 02:11 PM
