Drives: 2013 FRS / 2013 427 Vert
Caliper Clearance vs Heat Dissipation
I just bought a used set of 17x8 RPF1's to use as a second track option. Hoping that lighter (34#s) and slightly narrower is quicker. My concern with test fitting is the tight clearance between the caliper and the wheel barrel possibly creating additional heat. These 3 pictures are my 18" street wheels vs the 17" Rotas and 17" RPF1s.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
Drives: Nevermorange FRS
Won't be an issue. Just be aware of the location of the stick on weights so they don't get scraped off due to clearance and put heat-reflective tape (aluminum) tape over the weights. Otherwise the heat can reduce their sticky and they come off so the reflective tape keeps that from happening.
PRO86 | WTCC | STL
| Combating the heat | toekneehair | Forced Induction | 823 | 12-23-2021 08:06 PM |
| Heat Shields | X Factor | Engine, Exhaust, Transmission | 4 | 09-05-2014 03:47 PM |
| Heat cycled. | forwallblakmail | Tracking / Autocross / HPDE / Drifting | 23 | 06-25-2014 10:45 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
