Old 11-25-2015, 07:06 PM   #1
daironchef
Drives:
installation help (borgwarner efr turbo)
Okay I got my line correct now,
But I'm still over boosting
I ran the line directly into the waste gate skipping the electronic control solenoid - still over boost
I made sure my load is at 2turn or 3turn. But either way it's still going pass the set psi
So im thinking
a) my wastegate is not working? Any other easy way to fit out if it's not working except to find a compressor and blow some air in it to see if it open?
b) my boost gauge is not reading properly? I'm using scangauge 2 and using its built in BST reading. It's reading through ODB II. It reads around -10psi at cruise and open up to almost 20psi....which is not good
Any suggestion???
hey guys, i think i ran my line wrong w/ my turbo, hence my wastegate is not reading the pressure to open up at the desired PSI.
the 2 pictures below are not mine, but I have 2 ports (circled) i'm not sure where it should go to. can anyone help me out? I have the treadstone turbo kit (no instruction).
SOLVED!!
Thanks in advance
daironchef is offline   Reply With Quote
Old 11-26-2015, 11:38 AM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'll take a look at mine in a bit, but can tell you:
-The one marked A is a vacuum line
-The ones under B are the boost solenoid. One goes to the turbo and one goes to the WG actuator. The 3rd one isn't used. I'll take a look to see how it's connected.
kmbkk is offline   Reply With Quote
Old 11-26-2015, 04:18 PM   #3
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yep, B is hooked up just like the picture. My solenoid isn't on the turbo, though. I have it mounted in a different location, but it's still connected as shown, with the 3rd port not used.
Let me know if you have any other questions as I'm running the Treadstone kit as well.
The Following User Says Thank You to kmbkk For This Useful Post:
daironchef (11-29-2015)
Old 11-27-2015, 08:05 PM   #4
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I can take a picture and show you.
https://d1juqo69tkizbw.cloudfront.ne...93d9.large.jpg
texasbound972 is offline   Reply With Quote
Old 11-27-2015, 11:48 PM   #5
daironchef
Drives:
Originally Posted by texasbound972 View Post
Thanks! Looking forward to the pics
Old 11-28-2015, 01:12 AM   #6
texasbound972
USMC
Can't get any good ones. I'm trying to find some I already took.
The Following User Says Thank You to texasbound972 For This Useful Post:
Old 11-29-2015, 12:53 AM   #7
daironchef
Drives:
Still over boosting
Old 11-29-2015, 11:26 AM   #8
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Which wastgate actuator is installed? They have a low medium or high boost option. Im running the medium boost spring. It'll initially spike to 14 psi then drop to 12 psi.
Old 11-29-2015, 11:45 AM   #9
daironchef
Drives:
I'm running the medium one, but it doesn't seems like it is reacting to the setting on the wastegate.
Old 11-29-2015, 11:46 AM   #10
texasbound972
USMC
That's funny because I bought the high boost one and it peaks to 14 psi on waste gate pressure alone.
Old 11-29-2015, 01:58 PM   #11
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Try this to see if it helps.
Old 11-29-2015, 02:03 PM   #12
texasbound972
USMC
No image
Old 11-29-2015, 02:41 PM   #13
daironchef
Drives:
Yes I have adjust the preload to 2mm-3mm and that should give me 10-11psi but still over boosting
Old 11-29-2015, 02:59 PM   #14
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Post some pics of your install.
Treadstone Borgwarner EFR turbo kit daironchef Forced Induction 10 10-26-2015 12:33 PM
Cost of Supercharger or Turbo and installation. Wishbone32 Forced Induction 11 04-15-2015 09:21 AM
BorgWarner EFR / JDL turbo install!!! Infamous Performance Forced Induction 89 01-22-2015 12:38 AM
AVO turbo kit installation help/tips Fizz Forced Induction 19 10-29-2014 07:33 PM
Prices for turbo installation and clutch in LI whitefrs NY / NJ / CT / PA 24 03-07-2013 03:14 PM
