Old 10-29-2014, 11:08 PM   #1
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
BorgWarner EFR / JDL turbo install!!!
It was a project that took longer than expected. But, many projects involving custom fabrication work can take a bit longer than expected. In all the car was down for 16 total days (including weekends).
Special thanks to the great folks at JDL and Delicious Tuning for all their assistance in making this project possible.
Today we started up the first BorgWarner EFR /JDL turbo system. BorgWarner EFR turbo, JDL headers/FMIC/down pipe, Koyo radiator, Spal fans, Mocal oil cooler, DW65c pump, DW700cc injectors, Delicious Tuning MAP sensor.
The car was flashed with the Delicious Tuning "Flash n go" map for initial test and "break in". The car will be returning shortly for a full flex fuel kit install and dyno tune (on our Mustang dyno).
We will follow up with more data and results as time permits. Until then, some pix of the work/install and a short vid taken of the initial start up of the system.
the vid:
https://www.facebook.com/video.php?v...25102461339233
Infamous Performance is offline   Reply With Quote
Old 10-29-2014, 11:12 PM   #2
More pix:
Old 10-29-2014, 11:13 PM   #3
reserved for more pix/dyno charts.
Old 10-29-2014, 11:19 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Jesus that's a tight fit. Which turbo? Edit: 7670 jesus
Old 10-29-2014, 11:20 PM   #5
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Haha. My bad. Didn't see this till after I posted mine. Let me delete it.
texasbound972 is offline   Reply With Quote
Old 10-29-2014, 11:23 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
There are other BW twins. Treadstone has a BW kit, and Full Race is being expected by SEMA.
Old 10-29-2014, 11:43 PM   #7
texasbound972
USMC
Ok. Is there a thread?
Old 10-30-2014, 02:18 AM   #8
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I don't think you took enough pictures.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-30-2014, 05:11 AM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yeah just look down a few posts from this one for the full race thread.
Old 10-30-2014, 09:29 AM   #10
protpibe
protpibe's Avatar
Wow, thats a nice setup!
Whats up with the air filter and it's placement tho? It's going to wear a hole through itself on the ABS.
Old 10-30-2014, 09:41 AM   #11
texasbound972
USMC
Was actually thinking about relocating the washer fluid reservoir or getting a longer tube and extending it past the ABS
Old 10-30-2014, 09:43 AM   #12
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Looks nice. Don't forget to add some kind of heat shield to MAF harness, or it will melt.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 10-30-2014, 09:47 AM   #13
protpibe
protpibe's Avatar
That would probably be a big benefit for the temp of air it's taking in as well.
I modified a bunch of stuff to retain my washer fluid bottle in spring. I ended up removing the bottle in fall to install a meth pump and the tank was still like 95% full. I should of just removed it in the first place haha
Old 10-30-2014, 11:05 AM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thanks for all the pics. The different lengths of the bolts for the 4 bolt flange are bothering me though.
I'm thinking about going Motec for my turbo install... diss7 Forced Induction 29 07-16-2014 03:21 AM
Mackin FR-S Greddy Turbo Kit Install and Tune Evasive Motorsports Forced Induction 5 09-06-2013 03:30 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
SilverSkyline210's Full Blown Turbo Kit Install SilverSkyline210 Forced Induction 22 06-15-2013 04:23 PM
Shop in TN or MS to install and tune turbo brocktwalker Southeast 2 03-16-2013 09:58 AM
