Old 11-24-2015, 04:17 PM   #1
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Progressive Springs - Correct Orientation
I'm getting ready to do a spring install next weekend & I keep finding this question asked but there seems to be no general consensus.
Which is the correct orientation of the progressive spring on the shock? I was just going to install with reference to the lettering so that the letters are right side up, I don't think it should matter because the spring is going to be compressed the same amount either way.
Thoughts? :P
@Ultramaroon
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-24-2015, 04:26 PM   #2
8R6
8R6's Avatar
Drives: FRS
i wouldnt necessarily base it on the orientation of the logo, but the way it is currently in that pic is the correct way. the "tighter wound" part of the springs is on the bottom for the rears, and the tighter wound part of the springs is on the top for the fronts.
8R6 is offline   Reply With Quote
Old 11-24-2015, 04:26 PM   #3
jvincent
jvincent's Avatar
You are correct, a spring is a spring, so it doesn't matter which side is being compressed.
On some springs, I'm thinking of Bilstein here, they are different diamters so the seating on the spring perch and top hat would be affected. From the picture it looks like the coil diameter is the same at both ends so it doesn't matter.
Old 11-24-2015, 06:02 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Interesting. It does look like the rear coils have a decreasing radius near the top. The pitch also decreases so there's only one way for them to fit in the perches.
I'm not an expert. Gun to my head, I'd put the tighter pitch against the moving perch because that's the end with the lower spring constant. Less mass moving with the smaller perturbations.
It's probably the wrong answer.
Old 11-24-2015, 08:26 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The only time orientation of a spring will matter is if the top and bottom spring perches are of a different diameter.
-alex
Do Rear Suspension Springs Orientation Matter? krayzie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-02-2019 11:01 AM
Sticky tires still progressive? pseudo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-22-2014 06:23 PM
Linear (No progressive) springs Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 08-23-2014 05:23 PM
progressive springs 350matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-04-2014 12:38 PM
Progressive snapshot Yruyur Scion FR-S / Toyota 86 GT86 General Forum 11 09-25-2012 12:31 AM
