Old 11-22-2015, 10:16 PM   #1
MasonL1997
MasonL1997's Avatar
Drives: Man
Send a message via AIM to MasonL1997 Send a message via Yahoo to MasonL1997
Soot in Exhaust...Normal?
Hi everyone,
Ive had the car for just over 3 months and am the second owner with the car currently having 31 thousand kilometers. Now, when ever i go WOT and get out of the car after driving, i look at the exhaust and notice a small amount of black soot in the exhaust. Is this normal? Then if i dont clean it, after a fair bit of spirited driving i find the exhaust having quite a lot of soot inside it. Is this normal?
(Refer to pictures, one is still dirty, the other i have cleaned)
Thanks,
Mason
MasonL1997 is offline   Reply With Quote
Old 11-22-2015, 10:26 PM   #2
Impureclient
Drives: 2015 FR-S
Unburnt fuel from running rich. Normal.
The Following User Says Thank You to Impureclient For This Useful Post:
MisterSheep (11-23-2015)
Old 11-22-2015, 10:27 PM   #3
BRZ'13
BRZ'13's Avatar
Drives: subaru
Seems normal (i hope). All the cars iv owned/scene have jt. Just make sure its not oil. I dont even bother cleaning mine
BRZ'13 is offline   Reply With Quote
Old 11-22-2015, 10:45 PM   #4
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
It's totaled.
The Following User Says Thank You to KR-S For This Useful Post:
EAGLE5 (11-26-2015)
Old 11-23-2015, 12:01 AM   #5
MasonL1997
MasonL1997's Avatar
Drives: Man
running rich....will it cause injector problems down the track?
Old 11-23-2015, 12:02 AM   #6
MasonL1997
MasonL1997's Avatar
Drives: Man
It's totaled.
Damn it! I too fit in with every second post on this forum regarding a totaled car
The Following 4 Users Say Thank You to MasonL1997 For This Useful Post:
KR-S (11-23-2015), soulreapersteve (11-23-2015), Tcoat (11-23-2015), Ultramaroon (11-23-2015)
Old 11-23-2015, 12:10 AM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
No, the black "soot" you're talking about is just the carbon buildup due the afr being rich. All cars are set up to run a little rich in stock form - rich is "safe" from the manufacturer perspective. It will not cause injector problems every car has this buildup on the tips it's just some of them you can't see it. Also the FA20 uses Direct injection and port fuel injection. i.e. it has 8 injectors. Port injection still works much better for low rpm and idling for emissions & power. If anything were to be effected by soot it would only be the 4 injectors within the cylinders. At WOT at some points I'm pretty sure it uses both and you'll get that carbon on the tips the more frequently when that happens. Just keep cleaning it every month or so, so that it doesn't get caked on.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (11-23-2015), MasonL1997 (11-23-2015)
Old 11-23-2015, 12:25 AM   #8
MasonL1997
MasonL1997's Avatar
Drives: Man
Originally Posted by FRSBRZGT86FAN View Post
No, the black "soot" you're talking about is just the carbon buildup due the afr being rich. All cars are set up to run a little rich in stock form - rich is "safe" from the manufacturer perspective. It will not cause injector problems every car has this buildup on the tips it's just some of them you can't see it. Also the FA20 uses Direct injection and port fuel injection. i.e. it has 8 injectors. Port injection still works much better for low rpm and idling for emissions & power. At WOT at some points I'm pretty sure it uses both and you'll get that carbon on the tips the more frequently when that happens. Just keep cleaning it every month or so, so that it doesn't get caked on.
Awesome! Thank you heaps!
Old 11-23-2015, 12:31 AM   #9
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
If you're curious to learn more about the port / direct injection modes...you've come to the right forum!
http://www.ft86club.com/forums/showthread.php?t=50827
http://www.ft86club.com/forums/showthread.php?t=3172
aegisdrgn is offline   Reply With Quote
The Following 3 Users Say Thank You to aegisdrgn For This Useful Post:
FRSBRZGT86FAN (11-23-2015), MasonL1997 (11-23-2015), Ultramaroon (11-23-2015)
Old 11-23-2015, 12:34 AM   #10
Hotrodheart
Hotrodheart's Avatar
Hotrodheart is offline   Reply With Quote
The Following User Says Thank You to Hotrodheart For This Useful Post:
Old 11-23-2015, 07:26 AM   #11
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Is that the same black soot on the floor?
Braces is offline   Reply With Quote
Old 11-23-2015, 10:10 AM   #12
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 11-23-2015, 10:18 AM   #13
extrashaky
Drives: 2014 BRZ Limited
You can monitor your AFR with Torque to see if you're running the right mixture. It usually runs about 14.5 to 1.
Old 11-23-2015, 10:54 AM   #14
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Not under load.
jawn is offline   Reply With Quote
TRD Exhaust/Intake Installed - Super loud - Problem or Normal?? Chase86 Engine, Exhaust, Transmission 21 02-04-2019 01:02 AM
Undercarriage (exhaust piping) rust, normal? gonzalj1 BRZ First-Gen (2012+) — General Topics 18 09-21-2015 01:22 AM
IS IT NORMAL WGMGR Scion FR-S / Toyota 86 GT86 General Forum 40 12-08-2014 05:19 PM
Aftermarket exhausts causing black soot J_kennington Engine, Exhaust, Transmission 25 05-21-2014 09:40 PM
Water with black soot in exhaust KamalT Engine, Exhaust, Transmission 17 01-08-2013 09:28 AM
