Old 11-22-2015, 08:57 AM   #1
gconron_86
Drives: 2016 Raven Scion FR-S 6MT
Lowering spring FAQ- stock FR-S
Hello all, as you probably realize I am new here. Before I get flamed for starting a new topic, I will say that I did use the search button and looked all over for this question but could not find it! If I am wrong and it does exist, well then my bad Anyway, I am interested in a set of Eibach sportline springs for my 2016 FR-S. I am concerned about the longevity of the rest of the suspension components upon doing this mod, mostly because my car has about 750 miles on it at the time of writing and I don't want to be replacing things out of pocket due to the springs causing wear on other components. So, if I were to do the sportlines, what type of performance increases/decreases would I experience? And what other parts would it put wear on/damage? Also, are there better springs out there that have about the same amount of drop (1.4" or so all around) but are better fit for the car for a decent price? I do know about the TRD springs, but I have heard they are just rebranded Eibachs and they only drop the car about 0.9". I plan on keeping the stock wheels on the car for a while with the exception of possibly running spacers with them to get a slightly cleaner look. Thanks to all who read this and want to help out a new 86 owner
gconron_86 is offline   Reply With Quote
Old 11-22-2015, 10:14 AM   #2
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
-Review's for Sportlines:
http://www.ft86club.com/forums/showthread.php?t=15079
http://www.ft86club.com/forums/showthread.php?t=14674
I would read this too:
http://www.ft86club.com/forums/showthread.php?t=9936
And there is a ton of good info here:
http://www.ft86club.com/forums/showthread.php?t=45554
And here:
http://www.ft86club.com/forums/showthread.php?t=8739
With as much drop as the sportlines provide, you will bring on some negative camber, which can be fixed if you don't want it with camber bolts (front) and lower control arms (rear). From what I understand, anything more than about 1" drop will effect the longevity of the strut but I do not know how much.
The general consensus seems to be that proper coilovers are the best bet for both longevity and performance, especially if you plan on tracking and/or doing a lot of spirited driving. With that being said, my car is still at stock height so I cannot speak from personal experience. I know that I am going to be purchasing the Tein Flex Z coilovers here pretty soon. They have gotten really good reviews and aren't too expensive.
IMO if you are looking to get more than 1" of drop, I would hold off until you can buy proper coilovers.
Hope this helps!
-J.B.
golfyankee2121 is offline   Reply With Quote
Old 11-22-2015, 03:35 PM   #3
ryoma
ryoma's Avatar
definitely go with height adjustable coilovers if you want a 1.4" drop. however, even if you do get springs that drop close to 1.4", your shocks won't blow right away. you will just decrease their lifespan but how much exactly you decrease it by depends on the roads you drive. with springs that drop that low, you won't get full travel out of the shock and bottom it out more. our shocks in the rear already don't have much travel stock.
also don't forget to factor in a proper alignment after your drop. otherwise, your toe will chew up your tires bad.
eibach, fr-s, lowering springs, stock, trd
RS-R SUS lowering spring reviews? jvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-24-2014 12:44 PM
LOWERING WITH SPRING IN CANADA bhbnuckle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 03-14-2014 12:42 AM
WTB Lowering Spring FRS_Jack Want-To-Buy Requests 0 02-27-2014 12:48 AM
lowering spring noob friss21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-25-2014 07:27 AM
WTB: Spacers and lowering spring Swabe Want-To-Buy Requests 0 05-16-2013 09:06 AM
