Old 03-28-2015, 01:21 PM   #1
balci
steering wheel coming partially loose
Hello. recently installed a steering wheel hub and a nardi wheel on my BRZ. I did manage to bypass the airbag, but the TRC would stubbornly stay on. so I ditched that project and went back to the OEM wheel.
just two hours ago now, when driving home, the steering wheel came a bit loose by half an inch, immediately pulled over, and I still had the tools I needed with me. opened it up again, and found that the nut had loosened. tightened it up again pretty vigorously, in my head the wheel coming loose is just waiting to happen again though, and that's a potential disaster. so I'm retiring it for now.
mostly wanted to ask for what solutions you would suggest, and also if there is supposed to be a washer behind the nut holding the steering wheel on. I did not notice any when disassembling the wheel the first time, and I've looked all over the floor if I had somehow lost it.
is it as simple as some threadlocker?
thanks in advance
balci is offline   Reply With Quote
Old 03-28-2015, 02:54 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
If you tighten it enough it shouldn't be a problem again, I've had my wheel off twice now, each time just torquing the nut as much as I could and have had no issues.
There is no washer, just the flanged nut.
jonzhuxD is offline   Reply With Quote
Old 03-28-2015, 03:32 PM   #3
balci
alright, thanks. I didn't really check to see, but is there any way for the nut to come all the way off, sending me into a ditch with a steering wheel in my hands?
or does the head of the nut hit the airbag and keep it from coming all the way off?
I'll go buy some loctite on monday, put some of that on and torque it as hard as is feasible.
Old 03-29-2015, 01:50 PM   #4
jonzhuxD
Not sure, the loctite should hold with no issue though
Old 03-30-2015, 02:11 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hmm...concerning
Either way, if it feels "loose" again, just make sure to PRESS on the steering wheel, so you can at least maintain control of the wheel until you pull over without pulling it off.
loose OEM wheel at track speeds regandr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-09-2015 06:49 PM
Steering Wheel Leather coming off orlandorealtor Issues | Warranty | Recalls / TSB 34 01-21-2015 03:57 PM
Rattle in the Steering Column and loose key? Thehermdawg Issues | Warranty | Recalls / TSB 3 08-07-2014 03:51 AM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 10:02 AM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
