Old 11-17-2015, 09:28 PM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Dealer Caused Possible Electrical Issues
Actual Title: Dealer Caused Possible Electrical Issues
Thought I would post here because I have a limited time. Last week I got my BRZ fixed from an an accident with an 18-Wheeler. Now the right light of my rear license plate doesn't turn on. Also, the trunk no longer opens when I press the button between the rear plate lights. How would I fix this, or should I bother asking the repair shop to fix this? I only have tomorrow to fix this at the exact same dealer, so...
Edit: The dealer took off the trunk door in order to do repairs.
carma143 is offline   Reply With Quote
Old 11-17-2015, 09:35 PM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Did you make sure that the trunk release lock (button in trunk) wasn't on? Scratch that, BRZ is keyless so your button might work like my key slot in trunk.
Did you swap the license bulbs to see if it's not just a faulty bulb?
Old 11-18-2015, 12:32 AM   #3
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
i had this bulb issue on my FRS, What kind of bulb are you using and press the trunk button on the left hand side. Its usually a faulty bulb but my bulb would go out once every 3 days. Not sure why
http://www.maperformance.com/tech/wp...6-1024x768.jpg
BlackJesus is offline   Reply With Quote
Old 11-18-2015, 01:30 AM   #4
ryoma
ryoma's Avatar
the BRZ still has the key slot.
definitely double check to make sure that the license plate bulb is properly seated and that the trunk lock switch isn't activated.
The Following User Says Thank You to ryoma For This Useful Post:
KR-S (11-18-2015)
Old 11-18-2015, 01:42 AM   #5
carma143
carma143's Avatar
Yes, I have fiddled around with the trunk release lock, and that does not seem to be part of the issue. I have also tried opening the trunk using the button with my spare key with no positive outcome. I think that either the button was disconnected, or the sensors are no longer detecting that my key is "in range". The trunk still opens with the physical key hole and pressing the key's trunk button.
As for the rear license plate light, it is the same one that came with the car, LED. I have to assume that the connection isn't made because it was never reconnected.
P.S: My dad thinks they fried a circuit because they welded on a new bumper. I don't know.
Old 11-18-2015, 01:46 AM   #6
KR-S
Sporadic Member
KR-S's Avatar
Cool, thanks for confirming.
Old 11-18-2015, 01:50 AM   #7
BlackJesus
BlackJesus's Avatar
As for the rear license plate light, it is the same one that came with the car, LED. I have to assume that the connection isn't because it was never reconnected.
Okay, most led are low quality crap. Try replacing it with OEM to see if it work. LED tend to blow out more due to higher voltage since most LED are made to be used with low voltage setup.
As for you trunk, Does it open when you press the release trunk inside of your car? Does your key unlock/lock your doors? You might have a broken sensor or it isnt program to your key. Youll have to bring it back to the dealers and have them fix it.
Old 11-18-2015, 08:54 AM   #8
wparsons
wparsons's Avatar
Are you sure they actually welded anything on? The rear crash beam would be a bolt on piece. Even if they were welding, it wouldn't have fried a circuit. That absolute worst would be a popped fuse, in which case neither bulb would be working and no trunk release button would work.
Do the doors unlock still when you get close? If so, the car is detecting the key just fine.
It really sounds like they didn't connect everything back up properly when they put the trunk back on.
Take it back, make them fix it.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
NyC Zn6 (11-18-2015)
Old 11-18-2015, 11:41 AM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
yea I don't see the need to weld anything...where are you getting you info from?
Old 11-18-2015, 12:02 PM   #10
carma143
carma143's Avatar
So I had to go behind the shop where it says "no customers" in order to properly describe the problem to the workers. We found that the button was not working becauseo of a disconnected wire..Ha!
As for the right rear-plate light, we're still not sure. They're about to test it with a multimeter.
So I wasn't around when the car was finished. My dad took it and gladly drove it back to me in college. He relayed to me that they welded all or part of a new bumper. It was bent enough as it was, and, I would guess, it's really hard to perfectly bend back that metal. That's as far as I know about the welding.
The Following User Says Thank You to carma143 For This Useful Post:
Old 11-18-2015, 12:48 PM   #11
carma143
carma143's Avatar
It's all been fixed
The light was due to it not being plugged in.
