Old 11-11-2015, 11:06 AM   #1
afishl1
Drives: Raven FRS MT
Leak? Please advise
Not sure if I have a leak or what it is. I do smell something in the cabin if it's driven hard. Don't want to say much, but I am still N/A altho modified.
If there is an issue, please let me know if it's something easy I can fix (doubt it), or if I have to go back to stock and bring it in to the dealer?
Pics 1A and 1B are the same, 1A to give reference of where it is, 1B is zoomed in.
Not sure if the area in pic 2 is related or a separate issue if they are leaks?
Sent from my SM-N910T using Tapatalk
afishl1 is offline   Reply With Quote
Old 11-11-2015, 11:11 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Looks like valve cover and timing chain cover are leaking. Take it to the dealer, none of your modifications would make those gaskets leak, short of blowing up the motor.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
afishl1 (11-11-2015)
Old 11-11-2015, 11:15 AM   #3
afishl1
Ok, thank you very much...
Old 11-11-2015, 11:17 AM   #4
afishl1
I haven't touched any of those things, is it normal for them to be leaking around 30K miles?
Old 11-11-2015, 11:28 AM   #5
Not "normal" but not unheard of either. Sometimes engines leak. They will fix it up for you.
Old 11-11-2015, 11:29 AM   #6
afishl1
What is the actual fluid(s?) that are leaking?
How immediately does this need to be fixed?
I think ive been running like this for some time now...
I've also recently, inconsistently, been hearing a numerous clicking noise in 1st and 2nd in the low rpm range while under decent load.
Could that be the timing chain if that's leaking?
Old 11-11-2015, 11:35 AM   #7
Just motor oil. If your levels are ok there is nothing to worry about from that minor (appearing) leak. May want to have them check out the noise though even though it is not likely related in any way.
Old 11-11-2015, 11:36 AM   #8
afishl1
Ok... which leak, both?
Would either of those leaks be giving me a smell?
Old 11-11-2015, 11:39 AM   #9
Both.
Yes when the engine gets hot you could smell it. Also notice in the pics that there is some sort of debris in there (pine needles?) that could be falling on the header or exhaust and giving you an odour.
Packofcrows (11-11-2015)
Old 11-11-2015, 11:45 AM   #10
afishl1
Ok, yeah it could prob use a cleaning, leaf blower at least lol
The Following User Says Thank You to afishl1 For This Useful Post:
Tcoat (11-11-2015)
Old 11-11-2015, 11:50 AM   #11
Mine was the same until this weekend. Damned leaves. Make sure you check the tail light drains under the trunk lid as well. Mine were plugged solid with small leaves.
Old 11-11-2015, 12:04 PM   #12
afishl1
Yeah, seen that as well
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 04:10 PM
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 08:02 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 03:13 PM
Relationship advise? Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 821 07-10-2014 01:43 PM
Guys I can really use some advise... ScionFrsFan Engine, Exhaust, Transmission 27 12-31-2012 11:03 AM
