Old 11-10-2015, 08:15 AM   #1
ducky106
Drives: Scion FRS
Redline diff oil with LSD
I'm thinking about going with Redline for my differential oil and their website says its ok for clutch type LSDs but doesn't mention anything about Torsen diffs. Is this going to be ok for our car?
Here is the part from their website I'm talking about:
Contains additional friction modifiers for suitablity with clutch-type limited slip differentials - for most LSDs, no additional friction modifiers are required
ducky106 is offline   Reply With Quote
Old 11-10-2015, 05:45 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
This is all I found: "DO NOT USE Redline Shockproof or similar lubricants that contain microscopic soild particles in immersion to "cushion" differential components"
So as long as then redline you use isn't shockproof or anything that is similar you should be good.
Here's what a Torsen product book said: "Approved lubricants are Synergyn Syngear II, Motul Gear Competition 75w140, Motul Gear 300 75w90, and NEO Synthetics 75-90 RHD or 75-140 HD. The Torsen ATB diff dosen't require friction modifiers."
fumanchu1 is offline   Reply With Quote
Old 11-11-2015, 06:20 AM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
I have been using Redline 75W85 GL-5 gear oil for over 50,000 miles. No problem. I change it once a year in the spring. Make sure you get new drain/fill plug washers, as they are true crush washers, and are not re-usable.
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Redline 360 z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 2 07-17-2014 09:49 AM
FS: Redline MT-90 BMWDavid Transmission and Driveline 3 01-07-2014 08:52 AM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
Reaching redline. erom Engine, Exhaust, Transmission 27 07-23-2012 06:46 PM
