Drives: GTS 86
Chatter at low rpm when cold
For over a year I have been having this low rpm chatter coming from the front of the gearbox.
After I start the car in the morning and the rpm goes down to 700, I can hear a rattle/chatter in the gearbox. When I press the clutch the noise goes away but as soon as I take my foot off the clutch the noise is there. Initially I thought that the clutch or throw out bearing is on its way out, but I had the clutch changed by a professional and it seems that the noise is even more obvious now. |
Did you have the throw out bearing replaced along with the clutch ..... ??
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Hawk77FT (11-12-2015) |
Drives: 2013 ScionFRS
I have same issue if it even is one. Only when it's cold outside but goes away after warm. I'm sure it's just that.
Sent from my Nexus 6 using Tapatalk |
| The Following User Says Thank You to Tonypepatone For This Useful Post: | Hawk77FT (11-12-2015) |
Killed Scion
Drives: 2013 FR-S Whiteout
Throwout bearing. I can't remember which thread it was but this is common. What clutch did you put in (stock or aftermarket)? Also did you have the throwout bearing replaced when you got the work done?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
Drives: GTS 86
Drives: GTS 86
#7 | |
Drives: GTS 86
Even if it s brand new, you still think is the TO bearing? |
Hey, ....... that's Missouri speak ....... I learnt that after living there for 7 years.
@Tonypepatone .......... jest ah messen wich ya .... ![]() humfrz |
#10 |
Broaden your search. I get that there have been loads of throw out bearing issues reported but it seems that it has become the go to recommendation and people are missing the small stuff by looking only for the big.
My guess (without being able to hear, see or feel things) is a loose heat shield or such that only vibrates when it is cold and shrunk up a little. As things warm up it expands just enough to not vibrate. Like this: http://www.ft86club.com/forums/showthread.php?t=97195
#11 | |
Maybe they put it in backwards ... ?? Maybe they replaced it with another old one, that looked OK....?? Pay me no never mind ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-12-2015) |
#12 |
Conspiracy theories now Hum? Have you been taking your medication? Remember we talked about taking it on a regular basis.
| The Following User Says Thank You to Tcoat For This Useful Post: | Hawk77FT (11-12-2015) |
#13 |
#14 | |
Drives: GTS 86
Not really, as I can tell is from inside the gearbox rather than out. Plus, a heatshield would not be influenced by the clutch pedal.
Sent from my HTC_0P6B using Tapatalk |
| Valvetrain chatter on KW SC FRS | nlowell | Issues | Warranty | Recalls / TSB | 4 | 05-03-2015 12:20 PM |
| Flywheel Chatter | samisons | Issues | Warranty | Recalls / TSB | 13 | 12-05-2014 10:30 AM |
| Drivetrain chatter on cold mornings? | jm1681 | Issues | Warranty | Recalls / TSB | 7 | 10-24-2014 11:48 AM |
| Diff chatter when cold? | BRZrkr | BRZ First-Gen (2012+) — General Topics | 1 | 06-23-2014 10:17 AM |
| Odd Chatter Noise? | Chrisposey | Forced Induction | 5 | 05-05-2014 10:37 PM |
