Old 11-10-2015, 01:08 AM   #1
Hawk77FT
Drives: GTS 86
Chatter at low rpm when cold
For over a year I have been having this low rpm chatter coming from the front of the gearbox.
After I start the car in the morning and the rpm goes down to 700, I can hear a rattle/chatter in the gearbox. When I press the clutch the noise goes away but as soon as I take my foot off the clutch the noise is there.
Initially I thought that the clutch or throw out bearing is on its way out, but I had the clutch changed by a professional and it seems that the noise is even more obvious now.
Hawk77FT is offline   Reply With Quote
Old 11-10-2015, 01:58 AM   #2
Did you have the throw out bearing replaced along with the clutch ..... ??
Hawk77FT (11-12-2015)
Old 11-10-2015, 05:36 PM   #3
Tonypepatone
Drives: 2013 ScionFRS
I have same issue if it even is one. Only when it's cold outside but goes away after warm. I'm sure it's just that.
Sent from my Nexus 6 using Tapatalk
Tonypepatone is offline   Reply With Quote
The Following User Says Thank You to Tonypepatone For This Useful Post:
Old 11-10-2015, 06:11 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Throwout bearing. I can't remember which thread it was but this is common. What clutch did you put in (stock or aftermarket)? Also did you have the throwout bearing replaced when you got the work done?
Instagram: trevor.parque
Old 11-12-2015, 08:40 PM   #5
Hawk77FT
Drives: GTS 86
Yes I did! Replaced with a brand new one...noise still there.
Old 11-12-2015, 08:45 PM   #6
Hawk77FT
Drives: GTS 86
English please!
Old 11-12-2015, 08:48 PM   #7
Hawk77FT
Drives: GTS 86
Aftermarket clutch, new throw out bearing ,etc.
Even if it s brand new, you still think is the TO bearing?
Old 11-12-2015, 08:48 PM   #8
Tonypepatone
Originally Posted by Hawk77FT View Post
English please!
I blame the phone.
Old 11-12-2015, 09:33 PM   #9
English please!
Hey, ....... that's Missouri speak ....... I learnt that after living there for 7 years.
@Tonypepatone .......... jest ah messen wich ya ....
Old 11-12-2015, 09:34 PM   #10
Broaden your search. I get that there have been loads of throw out bearing issues reported but it seems that it has become the go to recommendation and people are missing the small stuff by looking only for the big.
My guess (without being able to hear, see or feel things) is a loose heat shield or such that only vibrates when it is cold and shrunk up a little. As things warm up it expands just enough to not vibrate.
Like this:
http://www.ft86club.com/forums/showthread.php?t=97195
Old 11-12-2015, 09:39 PM   #11
Do you trust they REALLY did replace the TOB .. ??
Maybe they put it in backwards ... ??
Maybe they replaced it with another old one, that looked OK....??
Pay me no never mind .....
Tcoat (11-12-2015)
Old 11-12-2015, 09:55 PM   #12
Conspiracy theories now Hum? Have you been taking your medication? Remember we talked about taking it on a regular basis.
Old 11-12-2015, 10:04 PM   #13
DANG IT! ...... I just knew there was something I forgot to do today ......
Hawk77FT (11-12-2015), Tcoat (11-13-2015)
Old 11-12-2015, 10:06 PM   #14
Hawk77FT
Drives: GTS 86
Not really, as I can tell is from inside the gearbox rather than out. Plus, a heatshield would not be influenced by the clutch pedal.
Like this:
Sent from my HTC_0P6B using Tapatalk
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 11:20 AM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 09:30 AM
Drivetrain chatter on cold mornings? jm1681 Issues | Warranty | Recalls / TSB 7 10-24-2014 10:48 AM
Diff chatter when cold? BRZrkr BRZ First-Gen (2012+) — General Topics 1 06-23-2014 09:17 AM
Odd Chatter Noise? Chrisposey Forced Induction 5 05-05-2014 09:37 PM
