Old 11-09-2015, 07:25 PM   #1
fr_s
fr_s's Avatar
Drives: '13 FR-S WHITEOUT
Please help, iJDM 4th Brake Light w/ strobe :(
Hi, I am a complete noob at wiring things. Looked at multiple DIY 4th brake light installs, but still confused. Has anyone done this specific one?
I looked at the iJDM install instructions ( http://store.ijdmtoy.com/Scion-FR-S-...tion-a/572.htm ), and it said to
Locate two specific wires; tail light mode and a brake light mode wires
and I found a site ( http://www.ft86club.com/forums/showthread.php?t=10816 ) that I believe is what I need to tap it into.
I ran the (+) wire from each 194 bulb to the driver side tail light harness. The green wire is the regular tail light. The red wire is the brake light. The ground wires went to the OEM ground location in the trunk.
I am confused because I have three wires. Pictures below...
I also found this link http://www.ft86club.com/forums/showthread.php?t=43087
http://www.mediafire.com/view/2bpjiu..._Taillight.pdf
Did I wire it right? Is the last one a ground? Where can I tap those three wires into? Visuals would help me most, but any help would be appreciated. Thanks!
\\ 3" Perrin RCBE [] Radium MCB [] SuperTek Intake Tube [] AFE DIF [] Kartboy Crank Pulley [] BRZ Swift Springs [] OFT //
fr_s is offline   Reply With Quote
Old 11-10-2015, 12:46 AM   #2
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
URL]
Its really simple. Red wire on the strobe goes to your brake light when the brake is being depressed. Black wire connect to strobe goes to ground and the last short red wire to your running brake ( the light that stays on ) Flip your headlight controller to the second dial where your running brake light and your front turn signal should turn on.
Go buy yourself some quick splice wire terminal
http://www.ebay.com/itm/like/1814922...chn=ps&lpid=82
it makes everything alot easier.
let me rephrase everything lol.
Long red wire thats connected to the strobe gets connected to the red wire.( on when brake is depressed.)
Long black wire thats connected to the strobe gets to be grounded. ( ground it as seen on picture. https://www.google.com/search?q=frs+...-XhiKdUzkQM%3A)
short red wire gets connected to green wire. (regular/always on when headlight is on)
if you need more help let me know. The wiring color on my brz is alot different so i can't be exact. It shouldnt be very hard. just tap on any of the color wires and depress the brakes. if your fourth brake signal strobes then that means you wired it right.
BlackJesus is offline   Reply With Quote
Old 11-10-2015, 01:05 AM   #3
fr_s
fr_s's Avatar
Dude thanks sooooo muchhhh for clearing it up! I'll give it shot tomorrow!!
Sent from my SM-G900V using Tapatalk
Old 11-10-2015, 02:40 PM   #4
fr_s
fr_s's Avatar
am i tapping into the right wires? @BlackJesus
is the out or in side of the strobe suppose to get grounded? wire seems a bit short...
Old 11-10-2015, 03:19 PM   #5
fr_s
fr_s's Avatar
nvm figured it out!
*edit with pictures for people that may run into this problem.
tapped into the wires from the diode: FR-S / BRZ Tail as Turn™ +Backup Module. So it is Red and Yellow instead of Red (brake) and Green (tail) from the blue and black wires.
Old 11-10-2015, 04:31 PM   #6
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I had this and it worked for a while then it kept giving me abs and traction control lights and a Brake light switch code so i removed it..would love to reinstall but hated that issue.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 11-10-2015, 08:01 PM   #7
BlackJesus
BlackJesus's Avatar
nvm figured it out!
is everything working correctly?
This shouldnt give you any error codes at all if wired correctly
Old 11-10-2015, 09:03 PM   #8
fr_s
fr_s's Avatar
So far so good.
Wouldn't the codes show up immediately?
Old 11-11-2015, 11:32 AM   #9
BlackJesus
BlackJesus's Avatar
So far so good.
it should. that means he must of did something else for the codes to appear.
Old 11-11-2015, 11:35 AM   #10
nickmerronesucks
Ned flanders
No i never changed anything else...tried running it as just brake light no flasher..still happened..disconnected it all together happened never again
Sent from my SPH-L720T using Tapatalk
797Performance.com
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
Reverse Bar / 4th Brake Light without a Light Bar? (to match OEM tails) cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-20-2015 01:24 AM
Rear fog brake strobe Gunman Cosmetic Modification (Interior/Exterior/Lighting) 8 09-09-2014 10:36 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
