Old 09-03-2014, 12:01 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Rear fog brake strobe
OK, I've had the rear fog wired with the parking lights for over a year, and just drilled a second socket for the brake light. Figured I'd get a strobe module for it to, but I'm not happy with how it looks.
I'm using Sylvania LEDriving 168/194/2895 white LEDs, and the LSC-100A strobe module from SuperBriteLeds. Basically the light never goes completely off, so the strobe effect is barely noticeable.
I'm not sure if the led isn't reacting fast enough, the module is messed up, or what. Other videos I've seen using this module have a fer distinct on-off flash.
Thoughts?
[ame="https://www.youtube.com/watch?v=QvdM-qQeFiY"]DSCN8967 - YouTube[/ame]
Gunman is offline   Reply With Quote
Old 09-03-2014, 12:21 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
So... you have 2 bulbs in there and only one is blinking? Are you sure it's wired correctly? I'd take it out and bench test it first. Perhaps you have some wires crossed.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-03-2014, 12:27 PM   #3
Gunman
Only one should blink, the other is wired to the parking lights, which are off in the video. IF both bulbs are on when the brake is pressed, then the car must be supplying a current to the parking lights as well...I suppose that is possible. Multimeter test should tell me that answer. If that is the case, the third brake light is isolated, so I may look at tapping into that, instead of the brake light at the tail light.
Old 09-04-2014, 02:40 AM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
If you wanted a 'noticeable' blink, you should have left out the running light function. If the blink is too fast, it will blend withe the running light. That and a single red 7443 (or 7440 for solo function) based bulb in red is brighter with a better color match. There really aren't that many LED's on a t10/194, so they probably aren't throwing out enough light.
Old 09-09-2014, 08:50 PM   #5
Simok
Drives: 2013 FRS
I have led interior lights from super Brite leds in my truck and they never turn off either always faintly lit.
Simok is offline   Reply With Quote
Old 09-09-2014, 09:14 PM   #6
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
when the "blink" is activated, power from the running lights circuit must be cut, otherwise as in the video, one bulb blinks, while the other remains lit constantly, which in turn gives the appearance of a dim "blink".
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 09-09-2014, 09:48 PM   #7
Gunman
Running lights aren't on in the video, that is only brake light.
Old 09-09-2014, 09:53 PM   #8
Danklvr
Danklvr's Avatar
my bad, i was looking at the red light in the upper left corner, thinking it was your tail light, now i see thats way too low for a tail..
Old 09-09-2014, 10:36 PM   #9
Gunman
I took out the strobe module, and replaced it with a standard turn signal flasher, and this is the effect. First is with only the brake lights, second is with the parking lights on.
[ame]http://youtu.be/bcD5999hFOo[/ame]
I'm going to add a relay to turn off the parking light in the rear fog, when the brakes are on, in an attempt to make it more visible at night.
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
Blue/Red Strobe Lights? 636 Cosmetic Modification (Interior/Exterior/Lighting) 15 11-04-2012 10:10 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
