Old 11-08-2015, 04:44 PM   #1
ryoma
ryoma's Avatar
Rear strut orientation
I was just wondering if the rear strut orientation matters? I recently swapped to RCE yellow springs and it turns out that I have the rear driver's side strut facing the wrong way (sticker on the strut facing out instead of in). I'm thinking that it shouldn't matter, but I just wanted to double check. I know that there's the indent on the spring perch for the spring to sit correctly, and I'm just hoping that since the spring would be compressed either way that the orientation of that indent shouldn't matter.
Old 11-08-2015, 04:56 PM   #2
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Springs has to be seated correctly. Not worth whatever risk and issues that might affect.
ottoyu34 is offline   Reply With Quote
Old 11-08-2015, 05:01 PM   #3
ryoma
ryoma's Avatar
the spring is seated on the perch correctly, just that it is facing a different direction than before since the whole strut is turned 180* from the original position.
Old 11-08-2015, 05:26 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I wanted to say "this side up" but i wouldnt be able to keep a straight face
Do Rear Suspension Springs Orientation Matter? krayzie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-02-2019 11:01 AM
Brand orientation! jdmblood Other Vehicles & General Automotive Discussions 19 07-21-2015 08:13 PM
Does orientation of the rear stock shocks matter? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-19-2014 05:47 PM
Spring orientation question theom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-05-2013 05:29 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 06:44 PM
