Old 11-07-2015, 06:30 PM   #1
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Front, Rear turn and DLR Question
Hey everyone, doing some shopping to replace those halogen with LED on the FRS.
Now I search a few threads and see that there's either the 7440 or the 7443 but couldn't find the answer for the correct bulb for the FRS. User manual just gives me the Halogen bulb.
Looking to replace:
Front and Rear Turn signal
and DLR.
What bulb size should I use to make sure its the appropriate one for the front turns, rear turns and DLR.
Also, do I need the load resistors for the front turns and DLR? Or can I just add those hyperfix relay instead?
Thanks!
xFury is offline   Reply With Quote
Old 11-08-2015, 12:39 PM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://www.diodedynamics.com/store/l...cion/fr-s.html
they will give you every bulb you will want!
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
xFury (11-11-2015)
Old 11-09-2015, 03:15 PM   #3
kspec
kspec's Avatar
Drives:
I picked up red 7440s leds for the rear turn signals and a led flasher from O'reilly auto. I haven't decided what I want for the front yet. Probably switch back 7443 leds. Plus the led bulbs bulbs I got actually have a lifetime warr. For whatever that's worth
kspec is offline   Reply With Quote
The Following User Says Thank You to kspec For This Useful Post:
xFury (11-11-2015)
Old 11-11-2015, 12:59 PM   #4
ringo16
Drives: 15 Asphalt FRS
Looking to replace:
and DLR.
Thanks!
DRLs are 9005. DRLs do not need resistors.
LED signals will need resistors or you can just get a flasher module.
http://www.modbargains.com/diode-dyn...hyperflash.htm
7440 and 7443 are the same sized bulb.
7443 is a switchback, which means it is dual colored (white/amber).
if you want the lights to remain the same color as stock, get 7440 for front/rear signals.
7443 for the front if you want the signals to be white as you drive, then flash amber when you signal
ringo16 is offline   Reply With Quote
The Following User Says Thank You to ringo16 For This Useful Post:
xFury (11-11-2015)
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear Amalgamo Brakes, Suspension, Chassis 3 04-24-2014 08:22 AM
Front Lip and rear bumper question edwardxu517 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-13-2014 08:25 AM
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 08:51 AM
Wheel + Suspension Question 18x9 +40 225/40/18 Front 235/40/18 Rear Asphalt~86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-10-2013 08:34 PM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 10:53 PM
