Old 10-07-2012, 01:02 AM   #1
jjdrivesajazz
Drives:
DIY: front and rear LED turn signal bulbs
today we did an install on JR's FRS, using our Automation Lighting LED turn signal bulbs, www.automationLED.com
these bulbs are factory size, features 13 super bright 3cell 5050 SMD LED's per bulb, and are available in WHITE, RED or AMBER. the best thing about these, they look white when they're off, so you don't get that orange reflection in your housing
front turn signal - 7443
rear turn signal - 7440
turn signal inline resistors - 1 pair for each pair of bulbs
in the state of california, front turn signals must be white or amber, and rear turn signals must be red or amber, laws vary from state to state, and it's totally up to you to decide what colors to use for your car, this is just something i'm letting you know in case you had questions about the law
we also used turn signal load resistors, 50w6ohm to be exact, to correct the "hyper flashing" issue. basically when you install LED's, they have a lower resistance than halogen bulbs, and they will blink at 2x rate as normal. these inline resistors simply tap into the wiring and regulate that resistance and it'll act like normal again, very simple, $10/pair from our site under the turn signal category
ON TO THE PICS!!
FRONT TURN SIGNAL
factory 7443 amber bulb
optional step, but if you would like to find the (+) and (-) wire of the harness, simply unplug the bulb socket and probe the 3 prongs with a multimeter, turn the signal on and you'll see the voltage go up to about 10v, then you'll know which wire to tap into for the resistor, in this case, it's the RED for POWER and BLACK for GROUND
LED bulb installed
50w6ohm inline load resistors, sold in pairs, 1 for each turn signal bulb
use the supplied wire taps and tap into the appropriate wires for the load resistor, it does not matter which wire goes to what, as long as it's the power and ground for that circuit, so take one side and tap it into the red and one side and tap it into the black, warning: the resistors do tend to get hot, so do not use zip ties or double sided tape, i would recommend to zip tie the wires up and let the resistor hang, you'll cause no damage this way
white LED turn signal installed
amber LED turn signal installed
some of you might ask, "why would i change it to amber LED if the factory bulb is already amber?" well it's because when the factory bulb is off, it throw an orange reflection in the housing, and i personally find it a bit on the ugly side, using these bulbs will appear white when off, and you'll get this clean look, plus they're brighter than factory and look a lot better
6000k crystal blue HID xenon headlights with white turn signal lights
that's all for the fronts, ON TO THE REAR
the rear is pretty straight forward, pop 1 clip from the trunk liner and you'll see the bulb and wiring, twist to remove and follow the same instructions for the inline load resistor. the rear turn signal is a single filament bulb so the wiring harness only has 2 wires, power and ground, so you won't need to test with a multimeter. just simply tap the turn signal load resistor into one of each of the wires and install the bulb.
here's the factory bulb when off, throws that orange reflection similar to the front
here's our LED turn signal bulb installed and off, looks much cleaner
using a red LED bulb
using an amber LED bulb
that's all to it! pretty simple, hope this DIY helps you guys and answers some of your questions
jjdrivesajazz is offline   Reply With Quote
Old 10-10-2012, 11:05 PM   #2
MrH
Drives: 20 Outback XT, 23 BRZ on order
Another forum member used 7440's for both the front and the rear on his BRZ. Any reason why you used 7443s in the front instead?
MrH is offline   Reply With Quote
Old 10-10-2012, 11:10 PM   #3
Gen
Drives: Scion FR-S
I believe 7443 are what you should be using. From my understanding, 7443s accommodate the third signal wire we have, whereas 7440s are designed for two wires.
Gen is offline   Reply With Quote
Old 10-10-2012, 11:16 PM   #4
jjdrivesajazz
Drives:
7440 is a single filament bulb, with 2 wires leads, 1 for power and 1 for ground, so it can either stay on or it can only blink
7443 is a dual filament bulb, with 3 wire leads, 2 for power and 1 for ground, so it can stay on AND flash or be used for brake light bulbs
you CAN put 7440 in the front, but you'll lose the parking light feature of the car, it is NOT recommended that you do this
Old 10-11-2012, 10:24 AM   #5
MrH
Great, thanks for the quick response!
Old 10-11-2012, 10:52 AM   #6
White64Goat
BRZ & FR-S have different parking/turn light configurations.
Old 10-15-2012, 09:53 PM   #7
jjdrivesajazz
Drives:
Yes, BRZ has the single filament turn signal with a separate parking light and the FRS has an integrated parking/turn signal dual filament bulb.
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Delete driver01 Canada Classifieds 0 09-21-2012 02:52 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
