Old 11-06-2015, 12:04 PM   #1
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Coilover alignment specs on stock parts
Hi all,
Just got a set of Tein Coils and dropped it a good amount, (1 finger gap all the way around).
Just wanted to post the final alignment specs on stock parts (lowers/bolts/etc), nothing changed except the coilovers.
Here's how it sits, for reference:
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 11-06-2015, 12:44 PM   #2
8R6
8R6's Avatar
Drives: FRS
which ones did you get? no adjustable top hats? almost no camber in front, but an avg of -2.5 in rear is an odd setup. i'd recommend at the very minimum, get some camber bolts to dial in a little more negative camber up front (probably bring you to around -1 to -1.5ish). then you can save up for either adj tophats for the front later and/or adj rear LCA's and bring in the rear camber back to like -2 or so.
8R6 is offline   Reply With Quote
Old 11-06-2015, 12:49 PM   #3
keb86
Drives: Toyota 86
Originally Posted by Rifle View Post
Hi all,
looks like even no LCA in the rear with that drop, it will be ok.
Wheel specs?
keb86 is offline   Reply With Quote
Old 11-06-2015, 04:07 PM   #4
Rifle
Rifle's Avatar
Down the road I'll probably get bolts and lowers but it's not a huge deal to me as I'm not tracking. It's a set of Tein street basis. Use OEM top hats.
As far as wheel setup,
17x9 + 35 w/ 255/40/17
295WHP/220TQ
Alignment specs Thatguyjeremy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-06-2015 01:49 PM
Low Price Guarantee: Stance and ISC coilover packages with SPL Alignment parts AutoRnD Brakes, Suspension, Chassis 20 08-01-2014 12:54 AM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 10:16 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
