Old 10-30-2015, 04:41 PM   #1
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
300 Lb Ladder in the trunk/backseat
So due to work purposes I need to have a ladder with me and I managed to fit it in my FRS with the backseat down and what not.
I know this might sound like a weird question, but can I expect any consequences of having a 300lb ladder in the back of my car 4/5 days out of the week?
I weigh 200lbs if that mean's anything lol.
Any help or information is appreciated thank you.
Roneezy is offline   Reply With Quote
Old 10-30-2015, 04:53 PM   #2
ST185RC
Drives: White Out FR-S
Well, first something is gonna get scratched up in your car. I don't care how well you wrap the ladder or how gently you handle it. If you bubble wrap it, even the bubble wrap can put marks on plastic. Little bits of gravel stuck to bubble wrap will eventually wear away at the interior of your car.
Second, depending on how you situate it, your dampers and everything connected to the wheels are going to wear our faster in the long run, than not handling a 300lb ladder.
Bottom line: you are putting more wear and tear on your car at the very least. Worst case, you start a butterfly effect and cause the planet to blow up from nuclear war linked to the ladder being in your possession.
ST185RC is offline   Reply With Quote
Old 10-30-2015, 04:56 PM   #3
Lorico
Drives: 2015 FRS
At least provide a photo of this 300lb ladder!
Lorico is offline   Reply With Quote
Old 10-30-2015, 05:00 PM   #4
M-17
Ninja Cat Mod
M-17's Avatar
To be honest, I'm surprised you got that ladder in the FRS. I'm usually surprised when anyone uses the 86 to store big items for certain occasions. Weight wise, you should be good. If you're really worried. Just take the ladder out at the end of the day or whenever its not in use.
Don't drive hard with the ladder in the car. Make sure you properly secure that ladder too. You'll very likely ding/scratch up your car.
Or... just a thought. I understand you need the ladder for work and all, but you're going to want to rent or buy a truck.
Old 10-30-2015, 05:08 PM   #5
fang_gt86
FR Noob
fang_gt86's Avatar
Only 300lb ladder I can think of.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 10-30-2015, 05:08 PM   #6
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
the best thing to do is to buy a beater for daily use unless other reasoning (financial...etc). I personally wouldn't lug around a 300lb ladder in my 86. The only thing I can see going wrong is your rear struts will obviously take a little abuse as I don't know the load rating on these cars.
Old 10-30-2015, 05:30 PM   #7
humfrz
For the life of me ...... I just can't imagine a 300 pound ladder that you could fit into the FR-S.
Help me out here .... ??
Sometimes, I carry about 300 pounds of passengers in my FR-S ...... and it ain't broke so far .....
humfrz
Old 10-30-2015, 05:53 PM   #8
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
humfrz
So you gave her a ride..??
Old 10-30-2015, 06:07 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
humfrz
One of those Little Giant folding ladders with a 300lb load capacity, I suspect. But if it is literally a ladder that weighs 300lbs, then I don't know.
MrDinkleman is offline   Reply With Quote
Old 10-30-2015, 06:34 PM   #10
humfrz
Originally Posted by TRD-X View Post
So you gave her a ride..?? ...........
Well, it WAS a short ride ........
humfrz
Old 10-30-2015, 06:46 PM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
It's a 300lbs lad (which is medium American size right rofl) Op just had a stroke and went errrr
fumanchu1 is offline   Reply With Quote
Old 10-30-2015, 06:47 PM   #12
strat61caster
strat61caster's Avatar
Confirmed, car will carry 600 lbs no problem (average of 4x 150lb passengers), you're good on weight.
Edit: True confirmation is on the door sticker, it lists a maximum weight.
ineedyourdiddly
Old 10-30-2015, 07:33 PM   #13
Ashikabi
Ashikabi's Avatar
So... how does a ladder small enough to fit in an FRS weigh 300lbs? Is it made of depleted uranium?
Old 10-30-2015, 07:48 PM   #14
roddy
roddy's Avatar
Drives: '13 Ultramarine
humfrz
HAHAHAHA, for some reason I found that very entertaining.
Folding down the backseat. Sparda29 Issues | Warranty | Recalls / TSB 18 04-07-2017 09:07 AM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 03:12 PM
New article - JDM spec "Review From The Backseat" sastexan Scion FR-S / Toyota 86 GT86 General Forum 7 12-04-2012 04:07 PM
Backseat buzzing solved (Seat belt retractor?) enivid Issues | Warranty | Recalls / TSB 1 10-05-2012 12:51 PM
Backseat .. am i too optimist? QC-FRS Scion FR-S / Toyota 86 GT86 General Forum 44 06-03-2012 07:52 AM
