Old 01-03-2013, 08:57 PM   #1
Sparda29
Folding down the backseat.
Dumb question, I've been trying to fold down the backseats to extend the trunk but I can't figure it out. How do I do this?
Sparda29 is offline   Reply With Quote
Old 01-03-2013, 09:08 PM   #2
OrbitalEllipses
Drives: Attitude
There's two lanyard-type things on the rear of the seat in the trunk, one on the left and one on the right side. Pull both.
JDMenrique (03-09-2014)
Old 01-03-2013, 09:09 PM   #3
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
gotta do it from in the trunk, took me a few the first time to.
Got3n is offline   Reply With Quote
Old 01-03-2013, 09:09 PM   #4
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
Release latches on the top inside the car, or pull cords in the trunk. Need to pull BOTH sides to get it to release.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 01-04-2013, 08:54 AM   #5
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
And make sure the driver and passenger seat are moved forward enough to fold the back seat down completely
Eurasianman is offline   Reply With Quote
Old 01-04-2013, 12:35 PM   #6
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
I believe only the trunk cords actually release the seat, otherwise you would not have a locked compartment from the cockpit.
smbrm is offline   Reply With Quote
Old 01-04-2013, 12:44 PM   #7
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Option 1: go to the dealership, give them $100 they'll do it for you
Option 2: find anyone on the street, give them $50, they'll do it for you
chenshuo is offline   Reply With Quote
Old 01-04-2013, 12:45 PM   #8
FRiSson
Drives: FR-S MT
You have to pull and push at the same time on tiny levers, while simultaneously moving the front seats forward and maintaining your balance while you are squeezed through a two foot opening and navigating between the junk that fills your trunk. Easy.
FRiSson is offline   Reply With Quote
Old 01-04-2013, 11:29 PM   #9
RazorHawk
Never been back there to check, but I thought there were some latches near the top corners of the seat, basically right where the pull cords are. Could be wrong, but thought there were.
5AD Spoiler
Old 01-05-2013, 12:19 AM   #10
cnk
Drives: '13 DGM BRZ Limited
Step 1 - Do as the posters above have said and use the cords in the trunk.
Step 2 - RTFM so you can avoid similar future posts such as why you can't open your trunk without the key.
cnk is offline   Reply With Quote
Old 12-11-2013, 01:22 AM   #11
Seraph
0_o
Seraph's Avatar
Drives: 2013 SWP BRZ, 1995 Black M3
... are you serious? The entire reason I need to fold my seats down is because the trunk won't open!
I'm hoping I'll find some advice somewhere around here. =/
Seraph is offline   Reply With Quote
Old 12-11-2013, 01:29 AM   #12
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Please go down these steps accordingly until your trunk is open
1. Try hitting the button on the trunk itself
2. Hit the button on the dash to open the trunk
3 use the button on your key fob to open the trunk
4. Use the physical key located in the key fob to open the trunk with the key hole
5. Noe that your trunk is open make sure you didn't accidentally hit the valet parking button located on the left side inside your trunk.
6. Don't feel bad I didn't know the valet parking button existed either.
cjsporl1996 is offline   Reply With Quote
The Following User Says Thank You to cjsporl1996 For This Useful Post:
Seraph (12-11-2013)
Old 12-11-2013, 01:36 AM   #13
Seraph
0_o
Seraph's Avatar
THANK YOU - you were right it was the Valet button X__X (stuff in the trunk rolled around and hit it I think)
Old 12-11-2013, 01:38 AM   #14
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
If you're inside the car you can pull up the rod that's in the back seat to fold down the back seats. It's located on top of the seat, at each side next to the seat belt strap. Remove the plastic housing and you'll see a red rod on each side
Zen86 is offline   Reply With Quote
The Following User Says Thank You to Zen86 For This Useful Post:
Seraph (12-11-2013)
Power folding mirrors trinitron Cosmetic Modification (Interior/Exterior/Lighting) 60 08-17-2016 12:00 AM
Backseat buzzing solved (Seat belt retractor?) enivid Issues | Warranty | Recalls / TSB 1 10-05-2012 11:51 AM
Fr-s Power Folding Mirrors? Koolkiid Cosmetic Modification (Interior/Exterior/Lighting) 19 09-15-2012 12:31 AM
Backseat .. am i too optimist? QC-FRS Scion FR-S / Toyota 86 GT86 General Forum 44 06-03-2012 06:52 AM
Power Folding Mirrors? migle BRZ First-Gen (2012+) — General Topics 30 04-20-2012 10:35 AM
